Farmer John
Posted: Wed May 20, 2020 5:46 am Post subject: Small Exterior Door Handle Screws. |
Hi everybody. I am wanting to fit the drivers door handle on my 1953 Lanchester but am getting dragged into an area where I know nothing, namely threads on tiny screws. I found two screws in my collection of tiny things and each has the diameter and pitch needed however the screw heads and lengths are wrong. I would have a go at shortening but the heads are no good to me.
If somebody could point me at the right diameter thread name and pitch I would be most grateful.
First screw, I measured the thread diameter at 0.108". Two attempts at counting the threads, 20 threads over the 7/16" screw length, and 11 threads over 1/4 of an inch.
Second screw, I measured the thread diameter at 0.177 or 0.18. Several attempts at counting these threads gave me 31 threads over an inch.
I am hoping someone can take into account the make and age of the vehicle and my fifty year old micrometer and vernier caliper and come up with some likely screw specs.
I do not know where I might buy these things here that is a major challenge to come.
Thanks in anticipation
John |
V8 Nutter
Posted: Wed May 20, 2020 8:42 am Post subject: |
| It looks as though the small one could be 6 B.A. and the big one 2 B.A. Search B.A. thread charts, you will find loads of info. B.A. was the common small thread system. |
Joined: 23 Nov 2007 Posts: 4272 Location: South Cheshire
Posted: Wed May 20, 2020 8:52 am Post subject: |
Hi John
Agree; It looks very much like a 6BA thread; 0.11" diameter 0.0209" pitch (about 48 tpi), and a 2BA 0.1850" 31.4 tpi.
BA threads are common on handles of this era.
Farmer John
Posted: Wed May 20, 2020 9:03 pm Post subject: BA screws |
Thankyou gentlemen, that is precisely the information I need. I can now shop with confidence knowing exactly what I want.
John |
Kenham
Posted: Wed May 20, 2020 9:45 pm Post subject: |
| Buy yourself a Zeus book, only a few pounds it will give you all the info you need. |
Miken
Posted: Wed May 20, 2020 10:37 pm Post subject: |
If you can't find what you want, Could you open the threads up with an M3 tap?
Metric screws are cheap and readily available. I won't tell anyone. |
Posted: Wed May 20, 2020 11:08 pm Post subject: |
You haven't mentioned the head style. If I remember correctly visible screw heads which I believe these to be, were usually countersunk but with a slightly domed top, and of course they would have slots not any of the other more modern aperture such as Phillips or Star etc. _________________ Bristols should always come in pairs.
Posted: Wed May 20, 2020 11:18 pm Post subject: |
| Miken wrote: | If you can't find what you want, Could you open the threads up with an M3 tap?
I won't tell either... for a price $£…  |
Posted: Thu May 21, 2020 3:14 am Post subject: |
John
Try your local model railway shop - they should have plenty. _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
