Engine overheat
Rollmop
PostPosted: Tue Aug 11, 2020 7:24 am    Post subject: Reply with quote
Thanks for all of your constructive replies. I could be a little cautious on the engine heat but, being a non pressurised system, the boiling point is going to be 100C and a contact thermometer has given 93C temperatures on the actual head. I have changed to Prestone coolant because they give a boiling point on their fluid of 129C. The gauge has recently been refurbished so I don’t think that is inaccurate. Perhaps I worry too much. Thanks again
Failure is not an option - in my case it is usually a feature.
1971 Herald convertible
1952 Triumph Mayflower
Rollmop
PostPosted: Tue Aug 11, 2020 7:32 am    Post subject: Reply with quote
Can I draw your attention to the article in the Mayflower club' website?
The one about issues with the thermostat?
http://www.triumphmayflowerclub.com/documents/flowerpowers/articles/
PostPosted: Tue Aug 11, 2020 9:18 am    Post subject: Reply with quote
When the thermostat opens it is also supposed to shut off the bypass hose. If the bypass is not shut off then much of your water circulation will not be passing through the radiator. You might be able to test this if you can shut off the bypass hose by clamping it.
PostPosted: Tue Aug 11, 2020 10:37 am    Post subject: Reply with quote
I have discovered that this is also a problem with XPAG engines where the original, rather sophisticated, thermostat is no longer available; or if it is, then it will be a reproduction that fails to close the bypass properly.
The answer that has been proven to work reasonably well, is fitting a common wax stat thermostat and adding a restrictor plate to the bypass opening. The small opening also acts as a breather.
PostPosted: Tue Aug 11, 2020 1:43 pm    Post subject: Reply with quote
The same problem also appears with the Triumph TR 4 cylinder engine. After replacing the "modern" type of thermostat with an old type bellows, the engine ran cooler.
PostPosted: Tue Aug 11, 2020 2:48 pm    Post subject: Reply with quote
Not wishing to hijack this thread ... but I wonder if the Land Rover thermostat (as above) will work in the XPAG. Only reason is the original design sells for nearly £100. !
alanb
PostPosted: Tue Aug 11, 2020 3:52 pm    Post subject: Reply with quote
If it has a water pump and thermostat then surely it is a pressurised system? The cylinder head will be considerably hotter than the water the best place to check the temperature is at the top hose or radiator header tank.
old tourer
Morris 8 two seater
PostPosted: Tue Aug 11, 2020 4:27 pm    Post subject: Reply with quote
I agree with that.
Also, non pressurised systems rely entirely on thermo syphon and likely will have a taller radiator probably with a Boyce or Calormeter mounted on the top.
Once pressurised systems could be thermostatically controlled, manufacturers became so confident that they often did away with the water temperature gauge.
alanb
PostPosted: Tue Aug 11, 2020 4:44 pm    Post subject: Reply with quote
My Morris 8 is thermo syphon and has a very tall radiator compared to a modern pressurised one, on the cars I’ve had with a temp gauge Normal has been around 80c
old tourer
Morris 8 two seater
Rollmop
PostPosted: Fri Aug 14, 2020 10:37 am    Post subject: Reply with quote
The Mayflower is a bit of an oddball regarding the cooling water, yes it has a water pump so it is not thermosyphon but it does not have a pressurised radiator and has a free to atmosphere overflow. Regarding the thermostat, I managed to pick up an NOS early Landrover thermostat which has the bypass cover, I will however try the clamp on the bypass hose.
PostPosted: Fri Aug 14, 2020 10:53 am    Post subject: Reply with quote
What kind of filler cap does it have?
lowdrag
PostPosted: Fri Aug 14, 2020 11:33 am    Post subject: Reply with quote
My ears pricked up when I saw wax stats mentioned. I had a few for the Jaguar but they are all gone now and the new stats fail closed as opposed to open, which worries me a bit. So, are wax stats still available? The Jaguar ones are found in Zephyrs and many cars so not make or model specific.
PostPosted: Fri Aug 14, 2020 12:31 pm    Post subject: Reply with quote
Rollmop,
Many cars of the same vintage as your Mayflower had exactly the same arrangement. All the Austin range had water pumps, thermostats with un-pressurised cooling systems.
Keith
1926 Chrysler 60 tourer
1950 Austin A40 tourer
1999 BMW Z3
PostPosted: Fri Aug 14, 2020 1:53 pm    Post subject: Reply with quote
With a vent to air system like that a bottle at the bottom of the vent tube can capture the "lost" coolant and it might even suck it back into the rad when the engine cools down if the vent tube reaches the bottom of the bottle.
Even if it doesn't suck it back at least you have saved that coolant to put back in the rad and reduce the need to keep topping up with fresh coolant.
Page 2 of 3
