Joined: 23 Nov 2007 Posts: 4119 Location: South Cheshire
Posted: Mon Mar 01, 2021 1:34 pm Post subject: Moderns can rust |
A 4 year old clean looking top of the range Honda with a very rotten sill presumably repaired under the manufacturers warranty, very odd:
https://youtu.be/rW4Ql4DNgwc |
MrWhite
Posted: Fri Mar 05, 2021 10:21 pm Post subject: |
'Old habits die hard' and this is one of the car makers oldest but still serves them well when it comes to killing cars off, so you have to buy a new one |
Posted: Sat Mar 06, 2021 10:05 am Post subject: |
By 'moderns', I would include anything made this century [for me, the years pass, but I hardly notice them these days].....the prevalence of plastic panels, sill covers, wheel arch covers, etc says to me that makers aren't bothered if the underneath steel rots out, as owners won't see it until it's far too late, and the vehicle ends up scrapped as a result.
[A case of, perhaps, ''what the eye cannot see, the heart doesn't worry about?'']
The Honda's rot was in plain view. Or so it appeared.
How many moderns are hiding stuff like that underneath the sill covers, eh? _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Sat Mar 06, 2021 10:26 am Post subject: |
Try looking at any Jaguar made this century. F-types are known to have rusty rear suspension after one year, and the S-types and X-types are disappearing at a great rate of knots. It seems that the inner sills on an X-type have no protection whatsoever. |
Posted: Sun Mar 07, 2021 3:16 am Post subject: |
MrWhite wrote: | 'Old habits die hard' and this is one of the car makers oldest but still serves them well when it comes to killing cars off, so you have to buy a new one |
Another trick is making sure you can't get hold of small bits that end up being critical to gain an MOT pass... these guys know what they're doing right enough |
Posted: Sun Mar 07, 2021 3:59 pm Post subject: |
lowdrag wrote: | Try looking at any Jaguar made this century. F-types are known to have rusty rear suspension after one year, and the S-types and X-types are disappearing at a great rate of knots. It seems that the inner sills on an X-type have no protection whatsoever. |
So true!
When I bought our 2004 X-type estate four years ago it was rust free on the body. Half a year later, because I read many horror stories on Jag forums, I decided to take a look and took off the plastic sill covers. Both sills were covered in much surface rust. I was lucky and just in time - no rot through and I was able to de-rust it and put zinc paint over it. Few months ago I inspected it again and it held well - no further rust.
I am sure if I had taken no action the car would need new sills by now. _________________ a car stops being fun when it becomes an investment |
Posted: Sun Mar 07, 2021 5:54 pm Post subject: |
I know of a couple of X Type owners who have found the sills to be rotten both around the 14 year mark, one car was scrapped and the other repaired, the latter then developed a gearbox fault at 180,00 miles that resigned it to the scrap yard .
I suppose for some perspective "classic" mini owners would have bitten you hand off for sills that lasted 14 years!
One reason I posted the original post, is the peculiarity of the corrosion; when the outer sill is removed the inner looks as if its just come out of the factory? There didn't appear to be any sign of a previous repair, the sill isn't covered with plastic, yet it was so corroded that holes could be easily poked through it if it had corroded from the inside there surely would have damage to the inner sill, corrosion from the outside would had bubbling flaky paint long before the steel was perforated, something that would have been noticed by the owner of a new top end Honda?
Any thoughts?
dave |
Posted: Sun Mar 07, 2021 7:40 pm Post subject: |
Is it anything to do with the grade of steel used?
In other words, what has been mixed into the steel itself?
I know FIAT had an issue with the steel sheet they got from Russia as part of the Lada deal....Seemed to rot from its own insides? _________________ Dellow Mk2, 1951 built, reg 1952.
MrWhite
Posted: Sun Mar 14, 2021 10:24 pm Post subject: |
I think you just have to treat modern cars like they do the classics on TV. When you get them home, strip them down, labeling and cataloging all the parts and send the body to the sandblasters.
Re-building obviously being a reversal of the above procedure, according to Haynes, then you will have the car you actually thought you had bought |
Posted: Mon Mar 15, 2021 3:40 am Post subject: |
MrWhite wrote: | I think you just have to treat modern cars like they do the classics on TV. When you get them home, strip them down, labeling and cataloging all the parts and send the body to the sandblasters.
Many a truth spoken in jest... I find my moderns - none exactly new, but not decrepit either - need just as much TLC as a classic to keep rust away from the underbody, just as much scraping, brushing, painting and waxing... because although the factory paintwork lasts a few years longer nowadays they ultimately have just as many mud and salt traps built into the structure as the cars of 50 years ago, they just look a bit different |
Posted: Mon Mar 15, 2021 9:52 am Post subject: |
We (my wife and I) have had Lexus cars in recent years. They are not just about the most reliable and superbly built vehicles available but sufficient care has been taken to ensure they will be with us for many years to come.
That kind of protection and attention to detail doesn't come cheap. It is unfortunate that less expensive cars are not built to last because it falls to younger drivers to pick up the pieces - and they deserve better. |
jddevel
Posted: Tue Mar 23, 2021 8:28 am Post subject: Modern cars do rust |
Although slightly off subject thought I`d mention that in the last few days I`ve been stripping back to bare metal, panels on my `48 MGTC using electrolysis in a barrel of caustic soda. Pleased with the ease and result. |
Posted: Tue Mar 23, 2021 9:32 am Post subject: Re: Modern cars do rust |
jddevel wrote: | Although slightly off subject thought I`d mention that in the last few days I`ve been stripping back to bare metal, panels on my `48 MGTC using electrolysis in a barrel of caustic soda. Pleased with the ease and result. |
I have all my TC panels to strip yet and it would be interesting to learn more about the process. Would it be possible to elaborate on what you have done please?. TC wings are quite a big lump to do in one go. I should have imagined you would need a big bath tub!
I may need to have my panels blasted as the p/o painted straight over rusty original. Not even a primer.
The only advantage is that the paint comes off quite easily! |
Miken
Posted: Sun Mar 28, 2021 10:56 am Post subject: |
A while ago I had a quite new Fiat Punto ( yes, I know!) as my drive to work.
It was 4 years old when it developed an oil leak.
I was poking about with a screwdriver under it one day. I prodded the sump and the screwdriver went straight through the side.
This did not improve the oil leak at all.
It was also, possibly the least likely part of a car I would expect to corrode through.
It turned out that Fiat plastic coated the sumps on these cars, moisture got behind the coating and soon eat through the steel.
Later a new guy started at work with a similar car and asked me "have you had a new sump yet". So, a common problem.
The replacement sumps were painted steel only. |
Posted: Sun Mar 28, 2021 11:11 am Post subject: |
Miken wrote: | I prodded the sump and the screwdriver went straight through the side.
This did not improve the oil leak at all. |
The opposite I would think!
Miken wrote: | It turned out that Fiat plastic coated the sumps on these cars, moisture got behind the coating and soon eat through the steel.
Amazing. _________________ a car stops being fun when it becomes an investment |
