Is polarity important for a fuel sender?
misterbridger
PostPosted: Sat Nov 28, 2020 6:12 pm    Post subject: Is polarity important for a fuel sender? Reply with quote
Just bought a universal fuel gauge sender unit for my +ve earth Singer 9A, but the unit says -ve earth only. Is this important? It's just a variable resistor after all - or will it work backwards?!
PostPosted: Sat Nov 28, 2020 6:20 pm    Post subject: Reply with quote
If it is just a variable resistor then there will be no problem. If it contains some semiconductors then there might be a problem.
misterbridger
PostPosted: Sat Nov 28, 2020 6:35 pm    Post subject: Reply with quote
Thanks. Can't see any other electrical gubbins in there. Waiting for an answer from someone in Singer O C who's used one succesfully but he may have changed his car's polarity
misterbridger
PostPosted: Sun Nov 29, 2020 1:36 pm    Post subject: Reply with quote
Put a multimeter across the terminals and it does indeed work the same both ways, so I guess we're good to go. Panic over.
