V8 Nutter
Posted: Thu Feb 18, 2021 4:27 pm Post subject: |
My wife had a Singer Chamois as her daily driver for many years, it was a great little car and reliable, until our daughter passed her test. We gave her the Chamois, I don't know what she did but I had to change the clutch so many times I could do the job in twenty minutes |
Posted: Thu Feb 18, 2021 9:54 pm Post subject: |
My little Ginetta G15 had the Sunbeam Imp Sport engine and never gave me any trouble. The only unreliable thing in the car was the speedo drive gearbox at the front wheel. It used to get knocked off when the front suspension hit its limits.
Posted: Thu Feb 18, 2021 11:38 pm Post subject: |
Presumably your Ginetta didn't have the pneumatic throttle.
My Volvo 340 had a front wheel driven speedo, but that didn't use a gearbox, the inner cable passed through the centre of the stub axle and the squared end was driven by the grease cap on the outside having a square hole in it.
A very simple little idea.
Of course being rear wheel drive it meant that you didn't get any indication of wheel spin from the speedo, but the speedo cable was a lot shorter vthann it would have had to be if it had been connected to the finaldrive section of the transaxle. _________________ Bristols should always come in pairs.
Posted: Fri Feb 19, 2021 10:05 am Post subject: |
Penman wrote: | Presumably your Ginetta didn't have the pneumatic throttle. |
Only the very first Imps (first year, 1963) had that pneumatic throttle. While a good idea the bad quality of the components made it unreliable. Ginettas were from the seventies so never would have had a pneumatic throttle.
Penman wrote: | My Volvo 340 had a front wheel driven speedo, but that didn't use a gearbox, the inner cable passed through the centre of the stub axle and the squared end was driven by the grease cap on the outside having a square hole in it.
Of course being rear wheel drive it meant that you didn't get any indication of wheel spin from the speedo, but the speedo cable was a lot shorter vthann it would have had to be if it had been connected to the finaldrive section of the transaxle. |
Same as the Hillman Imp, was also driven by a pin in the grease cap so nothing new here! _________________ a car stops being fun when it becomes an investment |
Posted: Fri Feb 19, 2021 10:11 am Post subject: |
Dave Lane is someone who writes a lot about his changes and upgrades to his Chamois and Van, both on Facebook and the Imp Club Forum. His cars are in great condition. Fascinating with a very good eye on detail. Although lately he seems to be out of ideas to improve so resorts to less interesting things such as fitting blue lighting and so on.
The weather is nice today and promising for the next week, above 15 degrees. I need to get the my Chamois out of the shed and take it for a drive. Same kind of Chamois as Dave has although without the black bonnet (which I do not like about his car).
Picture is from 21 years ago. The Minx has been sold a few years ago.
Posted: Fri Feb 19, 2021 10:25 am Post subject: |
Yes, the Ginetta was similar. It used Triumph Herald front suspension that wasn't designed to take the drilled stub axle. A little right angle drive was screwed to the back end of the axle but there wasn't enough clearance between it and the spring.
