Posted: Thu Mar 11, 2021 1:53 pm Post subject: Where to obtain a quality car horn? |
This should be very easy, with Ebay positively bristling with relatively inexpensive and simple car horns. But I'm now needing my third horn since restoring the car, as they don't seem to last more than two years. In fact, the most recent one had its life extended to two years by soldering a couple of short lengths of cable onto the terminals, once the frail, original spade terminals had corroded away.
One of the problems is that the horn is necessarily exposed to road-crud on my car, so I need something which either has a sealed plug or compartment for connecting the wires, or comes with a couple of electrical wires already attached.
I hope someone has a recommendation. |
Posted: Thu Mar 11, 2021 9:51 pm Post subject: |
Colwyn500
Sorry, I don't recall your car, but if you're looking for something 'classic', I'd seek out a 50's/60's Lucas. They're pretty simple & rugged & most can be over-hauled or tuned quite easily.
Whatever you choose, a little di-electric grease on the connections should keep corrosion at bay. _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
Posted: Thu Mar 11, 2021 11:46 pm Post subject: |
ukdave2002 wrote: |
Contralube 770 is a great product for protecting exposed electrical connectors, but its got very expensive in recent years:
MVPeters wrote: |
Whatever you choose, a little di-electric grease on the connections should keep corrosion at bay. |
Thank-you both....I've had a tube of Contralube for a couple of years now and always use it on electrical contacts; it even helped when I dismantled the ignition-switch recently, when poor contacts were affecting the ignition warning supply.
PS. It's a Fiat 500.
The thing with most of the horns available is that the terminals corrode whatever you do; to the point where they just fall off. The best I've seen is on my VW T4, which uses a special, sealed plug-connector at the horn; I'll try to source a connector and then go for that type of horn. |
lowdrag
Posted: Fri Mar 12, 2021 8:40 am Post subject: |
A known problem sadly. Ater many years I bought the low and high for the E-type from, I think, SNG Barratt and they are good quality. I know I had a bit of a problem sourcing them, but there are many other parts suppliers such as Manners, Robey, Norman Motors, and so on. Again from memory, about £50 each. Of them all, I'd try Norman Motors first. HTH |
