shared fuses question
PostPosted: Sat Apr 03, 2021 12:41 pm    Post subject: shared fuses question Reply with quote
How can two or more accessories (say heater and indicators ) share the same fuse without both coming on at the same time?
When one thing is switched on will it not bypass the switch of the other where the wires join at the fuse box?
PostPosted: Sat Apr 03, 2021 1:04 pm    Post subject: Reply with quote
Ray,
Your fuse should be on the live side of your switches. i.e. between your battery and switches. Your appliances will be connected to the other side of their separate switches.
Keith
1926 Chrysler 60 tourer
1950 Austin A40 tourer
1999 BMW Z3
PostPosted: Sat Apr 03, 2021 1:05 pm    Post subject: Reply with quote
Aren't the shared fuses between the power feed and the switches rather than between the switch and the item in question?
PostPosted: Sat Apr 03, 2021 1:17 pm    Post subject: Reply with quote
Thank you gentlemen. You have answered my question.
