suitable dashboard connector
PostPosted: Sun Jan 02, 2022 11:44 am    Post subject: suitable dashboard connector Reply with quote
I wish to be able to easily plug in (or out) my new dashboard wiring so I am looking for a suitable multi plug connector.
https://www.switchelectronics.co.uk/12-pole-plug-socket-6a-terminal-strip-hyps-01712?gclid=Cj0KCQiAt8WOBhDbARIsANQLp94Z6-EKA8N4x3t8izzgpameNGAp9zciM8foMs-ieWeAUbJhWnLiwbAaAnNfEALw_wcB
Could someone tell me if this kind of 6 amps connector (O.K. with 230 volts) could get hot with 12 volts.?
What would you use?
PostPosted: Sun Jan 02, 2022 1:23 pm    Post subject: Reply with quote
Gosh, I used similar to those 40 years ago on one of my model railway layouts...
PostPosted: Sun Jan 02, 2022 1:46 pm    Post subject: Reply with quote
What are you trying to do, Ray? Is the idea to remove the complete dash easily without faffing around with the wiring at the back first? It's an idea I like... to make removing and replacing the dash almost as easy as changing a wheel Smile
PostPosted: Sun Jan 02, 2022 2:15 pm    Post subject: Reply with quote
Yes. The dashboard simply screws to the scuttle frame with some wood screws. I have had a new one made and as there is a separate dash wiring loom, it seemed to make sense to be able to simply disconnect a multi plug (and remove starter, speedo, choke and tacho cables of course)..
My original plan was to have the dash hinged so it could be simply folded down but it is a convoluted shape which complicates matters. If I could easily remove the dash I would also not need to take off the steering wheel.
PostPosted: Sun Jan 02, 2022 2:56 pm    Post subject: Reply with quote
Personally I’d avoid screw connectors and use something like this:
https://www.autoelectricsupplies.co.uk/product/39
These are made for automotive use, and much quicker to connect/disconnect.
PostPosted: Sun Jan 02, 2022 4:04 pm    Post subject: Reply with quote
Ray
I think you need something a bit more substantial than those.
But, realistically, how often do you think you'll need to access the dashboard? I wouldn't introduce any more connections than really needed.
2002 MINI Cooper 'S'
PostPosted: Sun Jan 02, 2022 4:54 pm    Post subject: Reply with quote
MVPeters wrote:
Ray
I agree but I will not be making any more connections than is needed to join the separate dashboard wiring to the main harness. It is more to do with wiring the dash away from the car (on the bench) then connecting everything as quickly and easily as possible.
I am also making some additional holes and covering the dash with leather; I need a bench for that too.
I am trying to avoid this... which while it does the job is not the prettiest or most convenient solution.
I will look for something more substantial.
Something like this perhaps?
PostPosted: Sun Jan 02, 2022 8:28 pm    Post subject: Reply with quote
Yes, they look a bit better.
My old Mini had 2 fuses - my 2002 MINI has upwards of 50!
Minxy
PostPosted: Sun Jan 02, 2022 8:50 pm    Post subject: Reply with quote
I strongly recommend investing in a pair of the proper non-insulated terminal crimping pliers. One of the best tools I ever purchased.
Minxy
PostPosted: Sun Jan 02, 2022 9:09 pm    Post subject: Reply with quote
PostPosted: Sun Jan 02, 2022 10:03 pm    Post subject: Reply with quote
Yes. I have seen several reports of dashboard fires in old cars. I take the view that manufacturers continued with the two fuse set up for far too long... then again, there was little concern for safety among the public.
If anyone can find a similar plug more "in keeping" with my age of car I would be delighted... Wink
PostPosted: Mon Jan 03, 2022 6:29 pm    Post subject: Reply with quote
I have found this Plessey n.o.s. "multicon" plug and socket. It looks like a quality item even if it has more terminals than I will ever need.
Any thoughts?
https://www.ebay.co.uk/itm/400983625384
PostPosted: Tue Jan 04, 2022 11:20 am    Post subject: Reply with quote
Any thoughts?
That Plessey a connecter designed to be chassis mounted; its uninsulated, not what you want behind a dash. As I previously posted use something like this:
Designed for the job, insulated, up to 15 pins and only few quid!
PostPosted: Tue Jan 04, 2022 11:24 am    Post subject: Reply with quote
Thank you Dave. I will go with that. Wink
