Posted: Sat Feb 19, 2022 8:35 pm Post subject: Sovereign Coupe |
On Facebook Market Place.
https://tinyurl.com/yhy4v7f8 _________________ Bristols should always come in pairs.
Posted: Sat Feb 19, 2022 10:30 pm Post subject: |
I know someone who bought a new one in yellow.
It was affectionately known as "the custard tart"  |
Joined: 31 Jul 2009 Posts: 1819 Location: Market Warsop, Nottinghamshire
Posted: Sun Feb 20, 2022 9:22 am Post subject: |
The 1.0 litre version must be a rarity  _________________ in the garage: a big empty space!
Posted: Sun Feb 20, 2022 10:19 am Post subject: |
| mikeC wrote: | The 1.0 litre version must be a rarity  |
...and a RHD car with kilometres on the clock?  |
Joined: 16 Oct 2008 Posts: 1175 Location: Upper Swan, Western Australia
Posted: Sun Feb 20, 2022 3:12 pm Post subject: |
Ray,
All our cars have had kilometres on the clock since the mid ninety seventies and our cars are all RHD.
1950 Austin A40 tourer
1999 BMW Z3
Posted: Sun Feb 20, 2022 5:28 pm Post subject: |
| Keith D wrote: | Ray,
Keith |
I hadn't realised you were in Kms that far back.
If that Jag is an Australian import the chances are that it may not be a rot box.
Ray. |
Posted: Mon Feb 21, 2022 9:27 am Post subject: |
The advert claims 'all new floors' about seven years ago, so it must have been pretty rotten at some time in its life. _________________ in the garage: a big empty space!
Posted: Mon Feb 21, 2022 10:12 am Post subject: |
| mikeC wrote: | | The advert claims 'all new floors' about seven years ago, so it must have been pretty rotten at some time in its life. |
Probably still is
Much as I like old Jags (I am an honorary life member of the JDC) I despair of the way they rot. |
Joined: 20 Aug 2008 Posts: 1486 Location: Netherlands
Posted: Mon Feb 21, 2022 12:34 pm Post subject: |
| Ray White wrote: | | Much as I like old Jags (I am an honorary life member of the JDC) I despair of the way they rot. |
In the 80s any classic Jaguar you would come across here in the Netherlands almost always were the result of a big body restoration. I wanted a Mk1 or Mk2 saloon but could not find an example which did not need months of welding. In fact I ruled out the Mk1 / 2 saloons because they have a strip of bodywork between the front and rear doors, making aligning the bodywork after the inevitably rust repairs at the bottom halves very difficult from a DIY perspective.
Later on, late 80s and during the 90s, you would see more and more imports from warmer climates. These were almost rust free, a phenomenon not seen before on classic Jaguars.
My 420 is a good example. It was imported from the US in 1998 and only has a few localised spots of rust instead of needing new floors, door bottoms, wheel arches etc etc. So I ended up with not a Mk1 or Mk2, but a 420 which has the same doors and filler strip in between. As far as I know the doors never have been off the car (and will not be as long as I own the car). _________________ a car stops being fun when it becomes an investment |
Posted: Mon Feb 21, 2022 12:50 pm Post subject: |
| badhuis wrote: | | Ray White wrote: | | Much as I like old Jags (I am an honorary life member of the JDC) I despair of the way they rot. |
My 420 is a good example. It was imported from the US in 1998 and only has a few localised spots of rust instead of needing new floors, door bottoms, wheel arches etc etc. So I ended up with not a Mk1 or Mk2, but a 420 which has the same doors and filler strip in between. As far as I know the doors never have been off the car (and will not be as long as I own the car). |
You are right. I like the 420. I know it was an interim model but it has real class! |
