Amercan Boneyard
PostPosted: Fri Jan 13, 2023 2:29 pm    Post subject: Amercan Boneyard Reply with quote
See what you can spot here.
What is the most unexpected for you?
What is the oldest type you can spot?
Don't stick just to the area where the map is cetntered, theres quite a lot further out from the centre.
https://goo.gl/maps/UZJ2NyMkH3RzfgDq5
PostPosted: Mon Jan 16, 2023 10:05 am    Post subject: Reply with quote
I recall my Brother having a book about the Desert Boneyard when we were younger.
It had lovely photos, even with lines of B29's.
PostPosted: Sun Apr 16, 2023 7:52 pm    Post subject: Reply with quote
https://tinyurl.com/Boneyard-Prediction
Apparently no longer available.
It was a prediction that When the last 747 lands at the boneyard a DC3 and crew will be waitng to take the crew back to their base
Hence my prediction below, though that may now not come true because they are extending the Buff's life with RR engines talking about going past 2052 making the basic design over 100 yrs old.
I have a feeling the same will apply when the last Buff gets there.
PostPosted: Mon May 15, 2023 2:28 pm    Post subject: Reply with quote
I have been browsing round the Boneyard again and found this
https://maps.gstatic.com/tactile/pane/arrow_left_1x.png
Is that a Bone on the W side of the Galaxy ?
The reason I am querying it is because the tailp[i[pes don't seem to match exactly with a 3 view plan diagram.
Incidentally I have heard that the US is deploying a full unit of Bones to Fairford this spring/summer.
I wonder why!!!!
PostPosted: Tue May 16, 2023 6:10 pm    Post subject: Reply with quote
I don't know why that link didn't work. Anyway the Galaxy is at the southern edge of in the LOT immediately to the east of
https://goo.gl/maps/D5orzCtB6WAg2NHc7
PostPosted: Wed May 17, 2023 6:11 pm    Post subject: Reply with quote
Maybe expressing my inner Shakespeare will push you.
So:-----
Come on folks surely one of you can confirm it "To Be One or not to Be One"
bjacko
PostPosted: Fri May 19, 2023 7:48 am    Post subject: Boneyard Reply with quote
Certainly looks like a C5A Galaxy. maybe it is full of corrosion and beyond repair?
1985 Rover SD1 VDP
PostPosted: Fri May 19, 2023 12:17 pm    Post subject: Reply with quote
Hiu
I'd figured out the Galaxy because when I saw the apparent size I checked Wiki for survivors and the one at Davis Mopnthan is mentioned.
I'm still not sure about the B1, apart from the tail pipes I mention above I can't see any sign of the nose cone winglets.
PostPosted: Sat May 27, 2023 11:33 am    Post subject: Reply with quote
Apparently RAF Fairford is now home to a deployment of Bones, they started arriving this week, but their support crews and kit arrived 2/3 weeks ago.
This does not appear to be short term temporary, so what are they doing here?
Could it be a bit of Sabre rattling?
