Using both Al-Ko and traditional towing hitches
PostPosted: Fri May 12, 2023 8:16 am    Post subject: Using both Al-Ko and traditional towing hitches Reply with quote
I tow a few things the bulk of which are trailers with traditional Bradley hitches, and in the time honoured way, I grease the hitch socket to minimise wear. I will now be towing a caravan with the Al-Ko friction hitch, where any hint of grease could contaminate the hitch friction lining.
Clearly I could clean the tow ball up with brake cleaner before attaching the Al-Ko hitch, however its a bit of a pain as I frequently need to shift the trailers / caravan around due to the tight way everything is stored.
I can't be the first person to have this challenge? It's not the end of the world if I do have to clean the ball every time; just a bit of an inconvenience, especially when you are just shifting things around.
any thoughts?
PostPosted: Fri May 12, 2023 11:15 am    Post subject: Reply with quote
Could you use one of these?
https://www.amazon.co.uk/dp/B09471NFV7?tag=picclick02-21&linkCode=osi&th=1&psc=1
If you fitted the 2 balls with one at one end of the slider and the other one upside down at the other end. The through pins wold enable you to switch relatively easil. Plastic ball covers should keep road dirt etc of them when not being used.
PostPosted: Fri May 12, 2023 4:06 pm    Post subject: Reply with quote
I'd have two towballs if I was in that position, only a couple of bolts to switch them over. That is if you can actually unbolt the towball from the bracket, or I'm guessing if it's your modern then maybe it doesn't have a removable towball at all?
PostPosted: Fri May 12, 2023 4:29 pm    Post subject: Reply with quote
Hi Penman, Rick, it is my modern that I bought new last Sept, however getting the factory electric tow bar would have taken forever, so the dealer fitted a removable swan neck, I could get a 2nd swan neck (about £100) to use with the Al-Ko, seems a bit over the top, but at least no chance of contaminating the Al-Ko friction material
