V8 Wolseley
PostPosted: Sun Jun 04, 2023 9:16 pm    Post subject: V8 Wolseley Reply with quote
If very easliy offended, DO NOT look.
https://pre1960s.caryears.net/1958-wolseley-15-50-with-3-5-v8-5-speed-box-and-multiple-other-upgrades/?fbclid=IwAR2x_bb_jIrWLOjiKpPtlB6mjfXQeaxaW_ivd3j2356wPcTXbEyAQN4EIt0
PostPosted: Sun Jun 04, 2023 9:25 pm    Post subject: Reply with quote
I just don't see the point. It deserves to remain unsold.
I suppose it could be broken for parts?
PostPosted: Mon Jun 05, 2023 8:02 am    Post subject: Reply with quote
Why create such a poorly-fitting bonnet extension, and then pay for a 'professional respray'?
'Essentially needs finishing, hence the low price' - in other words I can't get it registered, you try!
PostPosted: Mon Jun 05, 2023 11:06 am    Post subject: Reply with quote
Nuts!
Peter Shocked
PostPosted: Mon Jun 05, 2023 2:22 pm    Post subject: Reply with quote
It is recorded on DVLA site, with the V8
Wholely inappropriate engine for that sort of car, in my book.
No mention of how the rear axle [or, back axle ?] has been uprated or changed?
PostPosted: Mon Jun 05, 2023 3:36 pm    Post subject: Reply with quote
...if I might add...probably the best place for the 3.5 litre Rover V8 is either in a Rover,,, Range Rover,,, or ultimately a Morgan... Shocked
Morgan Plus 8. Now there's a car to be reckoned with... Cool
I know it's a Buick engine but I like it. I wonder how many +4 Morgans have become +8s??
PostPosted: Mon Jun 05, 2023 6:02 pm    Post subject: Reply with quote
Many I suppose.
I d not have a problem by fitting another engine in a car (all Jensens have a non-Jensen engine), even Rover fitted the Buick engine as you say. Some Jaguars used Standard engines before WW2, many more examples to be found.
But it has to fit and not by making an awful extension to the front of the car!
Also I feel the engine should at least be from the same period the car was made. But all in my opinion, anyone can do what they like - which sometimes might result in these awful monsters!
bjacko
PostPosted: Tue Jun 06, 2023 7:33 am    Post subject: Wolseley V8 Reply with quote
Why would you bother.
1985 Rover SD1 VDP
PostPosted: Tue Jun 06, 2023 9:13 am    Post subject: Re: Wolseley V8 Reply with quote
... because there is no accounting for taste...
Shocked
PostPosted: Tue Jun 06, 2023 11:25 am    Post subject: Reply with quote
Its hideous Shocked , reminds me of a sandal worn with a sock!
PostPosted: Tue Jun 06, 2023 12:15 pm    Post subject: Reply with quote
Probably not that many....if any at all?
IIRC, before the Wawer, Morgan tried a Ford flathead V8 in the 4/4 chassis....Found it to be 'incredible' up the Morgan ''test hill'' out of Malvern.
The downside was, Ford wouldn't supply the 'right' V8 engine!
IIRC, also, I believe Morgan made a special for his daughter.... a drophead coupe which might have contained the flathead V8?
My memory isn't too good these days [is it really brown bin day?] and I haven't got my Morgan books to hand at resent, to check.
Morgans always used someone else's engines [and gearboxes, in the 4 wheelers]...Coventry Climax, followed by the ''Standard Special' motor [different to Jagwar's Standard engines]... Ford sidevalve [1172cc]...Triumph and Standard big engines [2.2 litre, 2 litre]...which upset Triumph's boss, as Morgans, with his engine, were faster than the Triumphs, and cheaper to boot.. Then there were the Ford OHV engines, crossflows, etc....FIAT twin cams, Rover V8s, etc etc etc....
Nowadays they are all a bit handbaggy for my tastes.
PostPosted: Tue Jun 06, 2023 1:27 pm    Post subject: Reply with quote
The Plus 8 is basically a Plus 4 with a Rover V8.
Admittedly the chassis would need to be modified as per the original ... and the body widened slightly ... but I would think it is eminently feasible.
I expect the biggest difficulty would probably be getting it registered and insured. Rolling Eyes
PostPosted: Tue Jun 06, 2023 4:03 pm    Post subject: Reply with quote
When I see something like that it really does make me wonder what people are thinking...
PostPosted: Tue Jun 06, 2023 4:43 pm    Post subject: Reply with quote
That's just it; they are not!
As it happens, there is room in the Wolseley engine bay for the Rover V8. Several conversions have been done quite well ...without the need for an extension.
bjacko
PostPosted: Wed Jun 07, 2023 6:39 am    Post subject: Wolseley V8 Reply with quote
The Rover V8 is no longer than most straight 6 engines but it is wider. It has proven to be a very good engine fitted to many car makes as original.
1985 Rover SD1 VDP
