Joined: 30 Apr 2013 Posts: 4324 Location: The Somerset Levels
Posted: Mon Jul 31, 2023 7:43 pm Post subject: Rad Weld |
Anyone any recommendations on a suitable rad leak sealer? _________________ Various Rootes Vehicles. |
Joined: 14 Oct 2016 Posts: 2281 Location: East Yorkshire
Posted: Mon Jul 31, 2023 8:19 pm Post subject: |
I suppose Radweld works as effectively as many others?
Then there's this?
https://fernox.com/product/leak-sealer-f4-500ml/
Not as cheap as the auto leak sealers, but for older vehicles' with cooling systems which have materials not seen these days in cars, maybe more effective? [Including aluminium!!]
Obviously the Fernox stuff [for central heating systems] treats a far larger system than found in most cars, but I guess some proportionality should work?
The difference I suppose is that most auto leak sealers aren't intended to be 'permanent?'
Whereas the Fernox stuff is..
Rolls Royce purportedly used Fernox Alphi-11 antifreeze in their older vehicles....stuff made for central heating systems as well... _________________ Dellow Mk2, 1951 built, reg 1952.
consul 57
Posted: Tue Aug 01, 2023 6:54 pm Post subject: |
| Rick wrote: | I've used K Seal and have had no problems.
RJ | i have used it on several vehicles and it seemed to work well |
Posted: Wed Aug 02, 2023 10:21 am Post subject: |
Thanks chaps, I had a good look round yesterday and K Seal certainly has some very good reviews. I've ordered some and will gladly give it a go. _________________ Various Rootes Vehicles. |
consul 57
Posted: Thu Aug 03, 2023 11:02 am Post subject: |
i have used the egg method in my first consul when the rad was leaking, it worked for a while. |
Posted: Thu Aug 03, 2023 11:39 am Post subject: |
| consul 57 wrote: |
Apparently the trick is only to use the egg whites.
(That's an old yoke... ) |
consul 57
Posted: Thu Aug 03, 2023 3:32 pm Post subject: |
| Ray White wrote: | | consul 57 wrote: |
yes we only found out later! |
Posted: Thu Aug 03, 2023 3:43 pm Post subject: |
I recall shoving several of the 'dogs' doings' radiator sealers into the gaping maw of a Frazer Nash radiator, on a Land's End Trial {MCC] pre-this century...
The leaking stopped, but I cannot recall whether that was due to the sealers, or the engine simply running out of water?
Rendering such assistance [it was at Minehead rugby club halt]...showed me how incredibly skimpy these Nashes were....One didn't really get very much for one's money! _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Thu Aug 03, 2023 7:18 pm Post subject: |
The K Seal has arrived and when I mentioned it to my Dad he said 'I've always used K Seal!!
Well you learn something new everyday! _________________ Various Rootes Vehicles. |
Posted: Tue Aug 29, 2023 1:49 pm Post subject: |
So, yesterday we took the Commer to a fairly local show, bout 12 miles each way.
We noticed though that a white froth started leaking from the overflow pipe and at some points the froth started bubbling out the rad cap???
She didn't feel overly hot to touch and she certainly wasn't steaming.
Anyone experienced that after they've added Rad Weld? _________________ Various Rootes Vehicles. |
Posted: Tue Aug 29, 2023 2:43 pm Post subject: |
| Rootes75 wrote: | So, yesterday we took the Commer to a fairly local show, bout 12 miles each way.
Anyone experienced that after they've added Rad Weld? |
I think it is fairly common. I was advised to flush the rad to remove surplus chemical and refill with clean water / antifreeze mix and the foaming will disappear. The rad weld will have done it's job with the leak. Once sealed it can't do anything more so the surplus is not needed in the system. |
Posted: Fri Sep 01, 2023 7:38 pm Post subject: |
That's what we'll do now, flush it through and fill it up again and see how she goes.
Don't think we'll do anymore shows now, although there is a steam up at a local pub next weekend, aside from that we will now have plenty of time for tinkering. _________________ Various Rootes Vehicles. |
