Thread Help, Please.
Penguin45
PostPosted: Fri Nov 03, 2023 12:18 pm    Post subject: Thread Help, Please. Reply with quote
Wolseley 4/44 gear knob by Penguin 45, on Flickr
That's a picture of the remains of a Wolseley 4/44 gear knob. As you can see, it's got a threaded hole in the centre casting. And that's where the fun starts.
The hole is 0.2555" or 6.49mm. As far as I can work out, the thread is 20 TPI.
5/16" UNC 18 will engage, but not advance.
1/4" UNC 20 is a drop fit - no engagement at all
5/16" W 18 is too big.*
M7 x 1 will fit and advance 3 1/2 turns before binding.
So, what's the thread? Any ideas appreciated.
Chris.
* My only Whitworth tap since a burglary...
Penguin45
PostPosted: Fri Nov 03, 2023 1:30 pm    Post subject: Reply with quote
Further to... I found a 1/4" W 20 die, so spun up a bit of bar stock. It's a drop fit, so no go. Logically, it must be 5/16". 5/16" 20 turns out to be a British Standard Cycle thread. Gosh.
Could anyone confirm this thinking before I go spending on taps and dies?
Chris.
PostPosted: Fri Nov 03, 2023 2:16 pm    Post subject: Reply with quote
It can't be cycle. 5/16" BSC is 26 TPI.
3/8" BSF is 20 TPI.
5/16" BSF is 22 TPI
If that helps?
PostPosted: Fri Nov 03, 2023 9:18 pm    Post subject: Reply with quote
Cycle threads can be either 20 or 26 tpi. There are cycle threads on pre war Morrises, the track rod being one.
PostPosted: Fri Nov 03, 2023 9:55 pm    Post subject: Reply with quote
Yes, but they would be too big for this.
You could have BSC with 20 tpi in 7/16", 1/2", 9/16", 5/8" etc.
....but not as small as 5/16" Wink
Kenham
PostPosted: Fri Nov 03, 2023 10:34 pm    Post subject: Reply with quote
In cases of trying to find what a thread is ,it is best to dismiss the task of giving it a name. If the thread you are measuring is 5/16th 20tpi then that is what the thread is. Whit, BSF, UNF, BA, cycle thread, whatever , the thread you appear to want is still 5/16 20tpi. I have some very strange taps , all made for some specific purpose no doubt and you will never find them in a thread chart. If you have someone who can cut a thread on a lathe you can try it to make sure before you buy a tap perhaps.
PostPosted: Fri Nov 03, 2023 11:22 pm    Post subject: Reply with quote
The Wolseley gear knob looks rather fragile and very discoloured with age. Understandably, you refer to the "remains".
I wouldn't like to say how long it might last in service before breaking up so perhaps a good replacement would be your best hope. I believe it should be imitation ivory with a chrome bezel at the end.
Good replacements are probably rare.
Best of luck.
bjacko
PostPosted: Sat Nov 04, 2023 5:50 am    Post subject: Wolseley Gear change knob Reply with quote
On the 4-50 and 6-90 the knob comes with the shaft to which it attaches. Are you sure it is not a tapered thread?
I imagine most of the BMC cars would have similar installations and use the same threads which at the time may have been unified.
1985 Rover SD1 VDP
PostPosted: Sat Nov 04, 2023 11:58 am    Post subject: Reply with quote
I recently had to figure out what an obscure internal thread was. I sprayed a light lubricant into the thread and filled the thread with glue from a glue gun, before it set I stuck a screwdriver in, 5 mins later when the glue is set simply unscrew, it?s far easier to identify what the male thread is.
Penguin45
PostPosted: Sat Nov 04, 2023 12:01 pm    Post subject: Reply with quote
Best of luck.
You should see the other side! It isn't there... The plan is to remake it for my club member. I can turn up a new centre insert and resin cast the outer. Who knows, there might even be a bit of demand for them. And no, there are no replacements to be had.
M8 was also suggested as a possibility. Wolseley was a Morris company from 1927 onwards and did some very strange things with metric threads. Anyway, it would engage the first turn of the thread but was too fat to advance. 1.25mm pitch on the M8, 20tpi translates to 1.27mm, so close but not quite.
Tracy Tools have 5/16" 20tpi taps and dies at a sensible price, so I suppose there is nothing for it but to invest.
Kenham is quite correct, the name is irrelevant - the object doesn't care. Anyway, lathe, mill and welder and you can make anything.
Cheers,
Chris.
Penguin45
PostPosted: Sat Nov 04, 2023 12:04 pm    Post subject: Reply with quote
Genius. Heads for garage...
C.
Penguin45
PostPosted: Sat Nov 04, 2023 1:09 pm    Post subject: Reply with quote
Returns...
Brilliant - all is revealed. 11 turns over 1/2", so 22tpi and tapered. Therefore, it must be a 5/16" 22 BSF tapered thread.
Tracy Tools have the taps. I can't recall ever having cut a tapered thread, so if there's any special techniques involved I'd be grateful for the information.
Dave, you're a genius.
Chris.
petelang
PostPosted: Sat Nov 04, 2023 2:13 pm    Post subject: Reply with quote
Shame there isn't a "Like" button as I reckon that from Dave was well worthy of one. Stuck that in the memory bank for future reference.
Daimler V8 250 1969
PostPosted: Sun Nov 05, 2023 10:05 am    Post subject: Reply with quote
+1
PostPosted: Sun Nov 05, 2023 2:28 pm    Post subject: Reply with quote
William Morris bought the Hotchkiss plant in 1923 and renamed it Morris Engines. A legacy of this was the use of obsolete threads. M8 x 1 is one such thread and is what MG used for the gear knob on my TC.
Unlike the 5/16"BSF thread on your Wolseley gear knob it is not tapered.
Well done Dave. You have cleverly shown that necessity is the Mother of invention.
