Southernscouse
Joined: 30 May 2024 Posts: 26 Location: Havant Hampshire
Posted: Thu May 30, 2024 12:52 pm Post subject: Coil voltage |
| Hi people first post I drive a 1954 Devon van with a cusp ark ignition and a alternator in a dynamo case this puts out a steady 14volts will this voltage kill my coil and would the fitting of a ballast resistor help the coil is the original Lucas Thanks Tom |
Joined: 23 Nov 2007 Posts: 4242 Location: South Cheshire
Posted: Thu May 30, 2024 12:55 pm Post subject: |
Hi Tom & welcome
14V wont harm a 12v coil, leave it as is. If you fit a ballast resistor to a 12v coil the spark would be compromised.
