Southernscouse
Joined: 30 May 2024 Posts: 27 Location: Havant Hampshire
Posted: Tue Mar 25, 2025 7:16 pm Post subject: Bleed nipples |
| 1954 Austin Devon van can anyone tell me the thread tpi of both front and back brake bleed nipples have put the same question on the accc site thanks |
Posted: Tue Mar 25, 2025 9:38 pm Post subject: Re: Bleed nipples |
| Southernscouse wrote: | | 1954 Austin Devon van can anyone tell me the thread tpi of both front and back brake bleed nipples have put the same question on the accc site thanks |
I think they are 3/8" x 24 TPi UNF.
Please don't just take my word for it. |
bjacko
Joined: 28 Oct 2013 Posts: 540 Location: Melbourne Australia
Posted: Wed Mar 26, 2025 5:54 am Post subject: Wheel Cylinder Bleed Nipple |
The wheel cylinders do not appear in the Lockheed Parts catalogue so I assume must be some other make. 1959 and on do appear.
Classicbrakeandelectric8 in Lincolnshire have a set of wheel cylinders for sale, maybe they can advise you the make and or part number/thread type for the bleeders. _________________ 1938 Morris 8 Ser II Coupe Utility (Pickup)
1985 Rover SD1 VDP |
Joined: 23 Nov 2007 Posts: 4287 Location: South Cheshire
Posted: Wed Mar 26, 2025 9:14 am Post subject: |
I'd advise checking the actual threads on the cylinders, reason being that pattern parts may well have a different thread to original.
They are almost certainly going to be UNF threads, probably either 1/4 " or 3/8". You may have different brands of cylinders on the same axle, so check each cylinder. |
