fuel filter location.
PostPosted: Sat Jul 12, 2025 11:20 am    Post subject: fuel filter location. Reply with quote
I always say you don't know what you don't know. I realise now that I have made an elementary mistake when fitting a fuel filter to my MG TC. I thought it would fit nicely to the outside of the battery box on the bulkhead so early on in the build, I went ahead and inserted the filter into the fuel line; after the pump and before the carburettor.
What I should have done, apparently, is locate the filter before the pump.
I have read that the reason why you don't want the filter between the pump and the carb is that
the pump is constantly trying to pressurise air in the filter and constant pressure on the float valve will cause it to leak and run rich. It can also cause problems when setting up the carb.
I had wondered why the float chamber tended to leak ...and now I know.
Hopefully my experience with this will be of some value to anyone else who didn't think it mattered where the filter was located...and hopefully avoid making the same mistake that I made.
I shall now have to move the filter to a suitable position before the pump and restore the direct line from the pump to the carb.
PostPosted: Sat Jul 12, 2025 11:55 am    Post subject: Reply with quote
I have both...before & after.
Don't have bother with leaks on the twin SU's.
Not long ago , Halfords [remember them?]... had an 'offer' on Crosland fuel filters which were actually specific to my Suzuki Not-so-very-Grand{!} Vitara, 2 litre petrol.
It is located at the rear, near the tank, but after the fuel pump.
OK, so the 'thing' is fuel injected, so 'high pressure'...and there are 'returns,' etc.
But the metal filters [a can, really] were nearly half the price of decent plastic inline filters...so I got a couple..[on a pension, needs must, etc etc?}
They have a side 'input' and a top 'output,' are fairly compact, so fitted onto the Dellow's bulkhead quite nicely.
Being a can, it is mounted vertically[on both the Suzuki, [a 2001/2 model] and on the Dellow..and, aside from rusting{?} won't be as prone to 'splitting' as the plastic filters when under 'pressure!'
I'm not so sure about this 'issue' of positioning of filters re-the pump?
I've never had the leaky carb issue.
What I do find concerning is when a plastic [AKA cheapoh?] fuel filter is mounted near the carb, but also near stuff that gets very hot, like exhausts?
If the plastic casing splits, guess where the fuel might end up?
In the past [Yup, I have a past!]...I have placed plastic filters after the pump location, but well down the side of the engine bay, a long way from anything hot....without issue at the carb[s]
The idea of the pump 'pressuring' the air in the filter if mounted after the pump really is at odds with one manufacturer of filters...and fuel pressure regulators!
Namely, Malpassi?
Commonly known as 'Filter King!'
The Filter King fuel filters also contain the fuel pressure regulator, so must be mounted between the pump and the carb[s]!
If an after-pump filter is going to create issues at the carb float chambers....why doesn't it do that with a Filter King mounted correctly?
I would ''suggest''....[if I dare, in such august company?]...also fitting a [Malpassi??] fuel pressure regulator....They do look rather nice, and would prevent over-pressure fuel supply, which can happen with a lot of electric fuel pumps used with carbs.
[Or, fit a small bore fuel return pipe back to the tank area...tee'd off the main fuel line at the carb? Then the carb simply draws what it needs?
Might also offset hot starting/fuel issues with today's petrol which vanishes rather more quickly than I'd like.
PostPosted: Sat Jul 12, 2025 12:43 pm    Post subject: Reply with quote
Thank you Alastair for such a thoughtful response. I like the idea of a return pipe to the tank. It is a nice traditional solution and wouldn't look out of place under the bonnet,,, though I am unsure how I would attach the end to the tank.(Remember, it is all exposed...)
AS it happens I would be new to Malpassi fuel filters and regulators and (in all honesty) a bit out of my comfort zone ...but I am willing to give it a try.
PostPosted: Sat Jul 12, 2025 2:19 pm    Post subject: Reply with quote
https://www.burtonpower.com/parts-by-category/fuel-system/fuel-regulators-filters-carb.html?srsltid=AfmBOoo0ABPr7t0HXiYbcYyqNGuVI1akT60BPNTZmw6cKU61pwZKOiYW
https://www.glencoeltd.co.uk/malpassi-carburettor-pressure-regulators/malpassi-filter-king-fuel-pressure-regulators/
Hi Ray, I included but a couple of retailers, although I haven't been a customer.
Just plucked off Google.
The filters for the Filter King are replaceable, thus perhaps offsetting the initial cost for the unit?
They are quite substantial bits of kit, so would look quite purposeful under the MG bonnet. A little less insubstantial than a plastic filter, etc?
Also, the fittings are all proper screw in items...
Also available from the likes of Demon Tweeks...
A return pipe to the tank can be as simple as, letting it into the tank filler tube, if there is one?
PostPosted: Sat Jul 12, 2025 2:37 pm    Post subject: Reply with quote
alastairq wrote:
..............A return pipe to the tank can be as simple as, letting it into the tank filler tube, if there is one?
There is no filler tube. It is quite primitive really.
However, I am warming to your more "substantial" suggestion.
Wink
PostPosted: Sat Jul 12, 2025 6:16 pm    Post subject: Reply with quote
I also have fuel pump into fuel pressure regulator into fuel filter without any noticeable issues. There is a sort-of filter in the tank, in the shape of a gauze "sock" that fits over the end of the pick-up pipe.
PostPosted: Sat Jul 12, 2025 8:36 pm    Post subject: Reply with quote
I think there may be differences between high and low pressure systems. Mine is an old fashioned low pressure S.U. pump located quite close to the carb.
PostPosted: Sun Jul 13, 2025 3:40 am    Post subject: Reply with quote
On my Austin A40 I have blanked out the engine block where the 'correct' mechanical fuel pump was fitted and have installed a low pressure SU pump on the firewall. I have fitted a plastic in-line Ryco filter between the tank and the pump. This has been 100% satisfactory. No problems at all (apart from the annoying rattle when the ignition is first switched on!)
On my '26 Chrysler I fitted an in-line plastic Ryco filter between the fuel tank and the firewall mounted Autovac tank. I was concerned that the filter would impede the flow of petrol to the Autovac tank as this is operated by engine
vacuum from a low compression engine. But again, no problems whatsoever.
I replace these filters (worth around $20 - about 10 pounds in your money) every year or so, depending on the cars annual mileage.
Keith
1926 Chrysler 60 tourer (100 years old! - a genuine antique!)
1950 Austin A40 tourer
1999 BMW Z3
PostPosted: Sun Jul 13, 2025 11:16 am    Post subject: Reply with quote
Hi Keith. Talking about A series engines, when I replaced my Austin A30 803cc engine with a 1098 unit from a late Farina A40. I had to convert from the original mechanical fuel pump to an electric one.
I learned a lot about petrol pumps from that experience. There are as you probably know 'pushers' - like the Austin/Morris 1100 (ADO16) used - that were mounted in the boot and "pullers" like the Morris Minor ones that sit on the bulkhead.
I also found to my cost that you can't use a high pressure pump where a low pressure one is required.!!
Back then, at the age of 19, I had a lot to learn... but fortunately my Dad was always on hand to set me straight....
Happy days. Very Happy
PostPosted: Sun Jul 13, 2025 6:13 pm    Post subject: Reply with quote
Similar here - I was intent on not removing the interior to get a power supply wire down to the back of the car*, so I bought a Facet Silvertop pump which is rated to pull the fuel far enough that I could mount the pump in the engine bay.
( * As it turned out it probably would have been quicker to pull the interior out as I had a lot of messing around with fuel pipes that were a very tight fit, all done at arms length.)
Miken
PostPosted: Sun Jul 13, 2025 10:15 pm    Post subject: Re: fuel filter location. Reply with quote
If you fit a Viton rubber float valve (available from Burlen ) wouldn't that solve any leakage problems?
PostPosted: Sun Jul 13, 2025 11:19 pm    Post subject: Re: fuel filter location. Reply with quote
I have no idea. The carb is a new 1.75" SU.
bjacko
PostPosted: Tue Jul 15, 2025 8:13 am    Post subject: Air In Fuel Filter Reply with quote
I am wondering why there is air in the fuel filter, surely it should be full of fuel?
1985 Rover SD1 VDP
PostPosted: Tue Jul 15, 2025 8:36 am    Post subject: Re: Air In Fuel Filter Reply with quote
Mine never seems to be, but then it's a low pressure system. Or maybe it's down to the angle that it's mounted at, or perhaps I haven't looked at it while the engine is running and I'm only thinking of it when it's stopped.
PostPosted: Tue Jul 15, 2025 9:27 am    Post subject: Re: Air In Fuel Filter Reply with quote
I have found another case where a filter is fitted between the pump and carb...and being made of clear plastic, it can be seen that the filter only fills at higher revs. At tick over it is only half full.... I don't profess to know why that is.
