Too posh to push?
PostPosted: Thu Sep 18, 2025 11:23 am    Post subject: Too posh to push? Reply with quote
https://www.carandclassic.com/l/C1940160
The quality is sublime. The styling superb. The price is right...but somehow I am intimidated by the prestige.
I tend to recoil from the Rolls Royce brand because it is such a strong image statement of class and privilege. Yet, somehow, what is basically the same car; but with a Bentley radiator, seems to invite me in to adore the quality of it's engineering.
This magnificent and extremely rare example of an aluminium Hooper bodied Bentley Mark V1 does, however, intimidate me. I would be totally embarrassed if it broke down!
The standard steel bodied cars were introduced after WW2 in an attempt to attract the owner driver but some chassis went to traditional coach builders regardless. This bumped the price up considerably.
Hooper were among the very best... for example, the shut lines of this "Empress" model are as good today as when it left the showroom.
Is it just me or would anyone else here be intimidated? Whereas the Standard Steel car is nice but relatively classless, I wonder if one requires a title and a Country Estate to do justice to such a beautiful car as this?
PostPosted: Thu Sep 18, 2025 6:26 pm    Post subject: Reply with quote
Must be a lot of work to get it in or out of that garage. No power steering I think...
"Cheap" because the leather is near its end?
Beautiful car but too big to actually use it (for me)
PostPosted: Thu Sep 18, 2025 8:04 pm    Post subject: Reply with quote
I have been unable to ascertain the exact length of the Hooper bodied Mark V1. One of the main reasons why I would consider a Standard Steel bodied Mark V1 is that it measures exactly 16 feet...
I have put a limit of 16 feet on any car that I buy ...so that eliminates the later R type Bentley and most other luxury saloon cars!
bjacko
PostPosted: Fri Sep 19, 2025 7:49 am    Post subject: Rolls and Bentley Reply with quote
Might be a bit big for the co-op car park eh?
1985 Rover SD1 VDP
PostPosted: Fri Sep 19, 2025 10:21 am    Post subject: Re: Rolls and Bentley Reply with quote
As I mentioned, I have not been able to establish the overall length of the Hooper bodied cars. At 16 feet, the Standard Steel Mark V1 is shorter than most Jaguars.
I suspect, however, you are right and the coach built car has a longer tail. As Badhuis mentioned, heavy steering at low speeds is the biggest drawback; although PAS could be retro fitted ... at a price!
norustplease
PostPosted: Sat Sep 20, 2025 8:41 am    Post subject: Reply with quote
The only intimidation factor for me would be the cost of repairs when it inevitably broke down!!
1953 Citroen Traction
1964 Volvo PV544
1957 Austin A55 Mk 1
Boring Tucson SUV
PostPosted: Mon Sep 22, 2025 11:51 pm    Post subject: Reply with quote
I think the prices charged for replacement Bentley parts are way more expensive than they need be.
One of the most common faults with these cars is how - after very high mileages - the rear wheel bearings fail. If the bearing has been rotating in it's housing it can spell big trouble. Shocked
Because the engineering is so robust, these cars keep on going even when they are completely knackered.! If you end up with one that has been driven into the ground; but tarted up for a quick sale, it can be a financial black hole.
Crashbox
PostPosted: Tue Sep 23, 2025 9:49 am    Post subject: Re: Rolls and Bentley Reply with quote
Waitrose it is, then. Laughing
My 1932 Morris Minor fits in one corner of a Waitrose car parking space. Very Happy
1989 2CV
1932 Morris Minor S.V. Two-Seater
PostPosted: Tue Sep 23, 2025 11:38 am    Post subject: Reply with quote
I quite like those trolley shelters.....My Dellow fits nicely inside one of those when it's raining...
[If full of trolleys, worth piling them all into a car parking space, then using the shelter....]
PostPosted: Tue Sep 23, 2025 11:57 am    Post subject: Reply with quote
Back in the days when there was an after hours period at super markets I had a couple of locations where I could get pupils to do the reverse park into trolley shelters. It really made them conscious of where the corners of the car and the space were, because they were so tight we couldn't have exited the vehicle.
PostPosted: Tue Dec 02, 2025 3:55 pm    Post subject: Reply with quote
That top picture in my memory looked a lot like this auction for an Armstrong Siddeley:
https://www.handh.co.uk/auction/lot/lot-68---1954-armstrong-siddeley-sapphire-346/?lot=62859&so=0&st=&sto=0&au=553&ef=&et=&ic=False&sd=0&pp=96&pn=1&g=1
(sorry for the big picture!)
PostPosted: Tue Dec 02, 2025 5:17 pm    Post subject: Reply with quote
Compare the Bentley Mk V1 (not the longer, but similar R Type) with an Armstrong Siddeley 346 Sapphire in this back to back review.
https://www.classicandsportscar.com/features/how-other-half-lived-bentley-mkvi-vs-armstrong-siddeley-sapphire-346
Just to give a glimpse into the rarified world of the Bentley Mk V1; you could have bought two new Armstrong Siddeleys and a Mk V11 Jaguar for the price of a Standard Steel saloon...with the coach built versions (like the posh Hooper above) half as much again. !!
I have a hankering for a Mk V1 Bentley simply for the engineering prowess ...but finding one that ticks all the boxes at a reasonable price is not going to be easy. The best ones are usually snapped up by dealers who want a big profit from them.
PostPosted: Tue Dec 23, 2025 12:22 pm    Post subject: Reply with quote
https://www.nostalgiatech.co.uk/new_page_10.htm
PostPosted: Tue Dec 23, 2025 11:20 pm    Post subject: Reply with quote
Overheating issues with the Mk 6 Bentley are, I think, true but over played. The lack of cooling passages around cylinders 2 and 5
tend to become a problem with high milage engines and are particularly acute in hard water areas. The "big bore" versions of this engine -
as the comparison shows - do exacerbate the situation but again there seems to be something of a bias towards the Jaguar.
The issue of chrome "cuff" liners in the bores is another interesting matter. I have been unable to find an engine builder who has actually
ever found a ridge; let alone one sufficient to cause piston rings to break. Perhaps only in very high milage engines which have suffered
from infrequent oil changes are these ridges found.?
That brings us to the biggest issue with the 4.25 engine; namely the bypass type oil filter system. This problem can be overcome by fitting
a full flow oil filter system...but like all things 'Bentley' it doesn't come cheap.!
