Brake Master Cylinder
PostPosted: Tue Sep 30, 2025 8:47 am    Post subject: Brake Master Cylinder Reply with quote
We are after a Brake Master Cylinder for our 1942 Commer Q2. The Master Cylinder is a Lockheed 14950.
We've had quotes of 400+ to replace this and tbh we haven't got that sort of money spare so wondering if anyone out there may know of one or know someone who might?
bjacko
PostPosted: Wed Oct 01, 2025 7:36 am    Post subject: Lockheed master cylinder Reply with quote
They are fairly rare used on only a few vehicles when looking through the Lockheed parts manual. The most likely place to locate one may be the Wolseley Car club as quite a few of their 1935 39 vehicles used the same unit. A Volvo car of the 1930's also used it as did some Tilling Stevens vehicles and Steels Engineering mostly mobile cranes.
1985 Rover SD1 VDP
PostPosted: Wed Oct 01, 2025 8:02 am    Post subject: Reply with quote
do you really require a new cylinder, can you not refurbish the existing one?
Seal kit is only £18.30 see below;
https://morrisregisterspares.co.uk/product/master-cylinder-kit-1-14-see-chart-104-106-cowley-4-6-1214-to-25/
PostPosted: Wed Oct 01, 2025 1:36 pm    Post subject: Reply with quote
The one we have taken off isn't correct tot he vehicle, its a later addition and has even had bracketry bodged together to keep it in the correct position.
We have stripped it however and all the internals appear in good condition, looks like its had a seal kit replaced before but we still get nothing from it.
There is plenty of suction when its plunged but it doesn't draw any fluid in at all??
PostPosted: Wed Oct 01, 2025 3:09 pm    Post subject: Reply with quote
Ahh, yes we sell them but as you have found out they are north of £400!
Try this guy; Dave Molyneux, he breaks pre war Morris vehicles, the same 14950 cylinder fits; the Morris 14/6, 15/6, 16, 18, 21, 25 Series II & III, 36-1939, for ref its 1.1/4" diameter, you can contact him at; dmmmem@tiscali.co.uk
PostPosted: Wed Oct 01, 2025 3:12 pm    Post subject: Reply with quote
I some picks of the one we've taken off, after cleaning the cast numbers still aren't eligible.
I will post a pic to see anyone may recognise.
PostPosted: Wed Oct 01, 2025 3:35 pm    Post subject: Reply with quote
This is what we have taken off...
PostPosted: Wed Oct 01, 2025 3:44 pm    Post subject: Reply with quote
That's very different to a 14950, here is where we get them from, you should be able to purchase one retail for around £219 although there will probably be VAT to pay.
https://ccparts.nl/en/product/master-cyl-s-outl-1-2-20-inl-3-4-16/
CC are the manufacturer who supply all the UK classic retail organisations.
Clearly there will be some re- plumbing required to fit the original!
bjacko
PostPosted: Thu Oct 02, 2025 8:12 am    Post subject: Commer Q2 Master Cylinder Reply with quote
The one shown is not a 14950.
According to a different section of the Lockheed manual it should be a 14896 is the correct unit. The Commer Q3 uses the 14950. The 14896 is a 1" bore unit Lockheed type B2.
It also doe not look anything like the picture above. It is used on Commer, Morris, Singer and Wolseley. Morris 10 and 12 SerII and 10 Ser III 12 Ser II 10 CWT van, quite a few Singer cars of the 1930's and a few odd Wolseleys use the one you want.
The repair kit is Lockheed Part number KL71410.
There is no Lockheed Cylinder that looks like the one in the picture.
Some of the cylinders don't have to suck fluid from the reservoir they are gravity fed.
1985 Rover SD1 VDP
PostPosted: Thu Oct 02, 2025 10:54 am    Post subject: Reply with quote
Looks to me like a past user has fitted, or tried to fit, dual circuit braking?
IE separate lines to front, and back brakes.
So fitting an original spec cylinder might also involve changing the pipework as well?
Have you tried pressurizing the reservoir using one of those pressure bleeding kits? [Spare tyre connected to reservoir top]?
Or, does the reservoir have an air hole in its cap, that is clear?
[Obviously too late now, as you've dismantled the system......but if fluid is not reaching the master cylinder, then an air hole in the reservoir cap that is blocked up, can cause the same issue...Much like a fuel tank with a blocked breather?]
PostPosted: Thu Oct 02, 2025 3:46 pm    Post subject: Reply with quote
The Cylinder that we have removed is just a one pipe in from the reseviour and then the old style banjo fitting at the back to take off a line to the front brakes and a line to the back.
Then it has the two long bolts through the casting to hold it to the homemade back plate.
PostPosted: Thu Oct 02, 2025 3:48 pm    Post subject: Reply with quote
The correct type should be a flange fitted master cylinder which our cross-member still has the original fixing holes for.
From another forum I am on I've been sent a copy of the Lockheed part book and Bjacko you're correct, for the Q2 it should be a Type B2 which is the 1" Bore 14896 not the 14950 which is a Type B1.
PostPosted: Mon Oct 13, 2025 10:25 am    Post subject: Reply with quote
This is the master cylinder stripped and cleaned off to show the casting numbers better. Any help identifying it would be appreciated.
petelang
PostPosted: Sat Nov 01, 2025 10:20 am    Post subject: Reply with quote
Tried past parts at Bury St Edmunds? They did my rare Daimler 15 cylinders. Came back sleeved, renewed seals, looked like new. Very reasonable.
Daimler V8 250 1969
