Reduced voltage.
PostPosted: Fri Oct 17, 2025 5:51 pm    Post subject: Reduced voltage. Reply with quote
The TC headlamps are not getting the full 12volts. In fact the voltage coming from the relays is only about half that!
I suspect a bad earth in area of the relays. Is it likely or possible? I have had problems with grounding in this area before.
PostPosted: Fri Oct 17, 2025 6:11 pm    Post subject: Reply with quote
How good is the wiring? Is it newer than the car, or could it just have deteriorated?
PostPosted: Fri Oct 17, 2025 6:51 pm    Post subject: Reply with quote
All the wires are new and all the connectors are soldered bullets. (I have probably just forgotten to tighten something.)
PostPosted: Sat Oct 18, 2025 3:40 am    Post subject: Reply with quote
You haven?t by chance wired the headlamps in series? That would give you half voltage.
bjacko
PostPosted: Sat Oct 18, 2025 9:54 am    Post subject: Earthing Reply with quote
Good earths are extreme;y important on our old cars, rust between contact areas is one of the most frequent causes of poor earthing. I ran separate earths to many areas that previously relied on returning through body contacts to the chassis.
1985 Rover SD1 VDP
PostPosted: Sat Oct 18, 2025 11:14 am    Post subject: Reply with quote
Now you mention it... I am trying to remember if I have wired the relays in series.
I suppose that would do it?
Confused
Having dismantled hours of work to extract the bank of relays Rolling Eyes I have reminded myself that the only series wiring that I did was with the earths.
I wanted to save space and thought a common earth would be O.K.??
All the other wires are installed in parallel .
PostPosted: Sat Oct 18, 2025 11:17 am    Post subject: Re: Earthing Reply with quote
No need to worry about rust. This is an Australian car and has no rust on it anywhere. I also run separate earths but mainly because it is a wooden body and there is a lot of new paint. Belt and braces really.
