Joined: 23 Nov 2007 Posts: 4443 Location: South Cheshire
Posted: Thu Aug 13, 2026 3:38 pm Post subject: Ultra light flywheel |
As I previously mentioned, my Innocenti Mini Copper Export has been depended on your era ; Tunned, Hotted up, Breathed on, for younger folk similar to mapping!
Looking through the vast array of the cars history, this included fitting an ultra light flywheel. Whilst this helps make the car more lively, the downside is that the slightest movement of the accelerator has an instant effect, not a problem when your foot is flat to the floor, but hit a slight pothole (with the cars fairly stiff suspension) would result in some accelerator movement with corresponding change in power at the wheels, resulting in more jarring, you certainly wouldn't want to do your driving test in this car!
At first I was thinking that given I'm going to do more local/ town driving, I'll fit a heaver flywheel, however now having done a couple of hundred miles I'm getting used to it (combined with the fact I have fitted seat extensions and a 13" steering wheel, so my legs now fit under the steering wheel ) I think I'll keep it as is? any views? |
Posted: Thu Aug 13, 2026 5:54 pm Post subject: Re: Ultra light flywheel |
| ukdave2002 wrote: | As I previously mentioned, my Innocenti Mini Copper Export has been depended on your era ; Tunned, Hotted up, Breathed on, for younger folk similar to mapping!
I always thought the Mini Cooper S was a fun car so can see exactly where you are coming from (or going to ).
I had the MG TC flywheel lightened but gave instructions not to take too much off as from experience I have found it can cause a lumpy tick over. The most important thing (in my opinion) is to have everything balanced. In that respect you could probably save on costs by having weights added to your existing flywheel.
bob2
Posted: Mon Oct 19, 2026 11:47 am Post subject: |
One of mine's got the whole bottom end lightened and balanced and it goes like stink, granted with a 3.44 final drive it is low so very good acceleration off the line but to the detriment of revving too much and then on top gear it wil hurt your ear buds cause revs are too high.
But still, great fun!
Does yours have straight cut gears too? |
