Crown Wheel And Pinion Identity
bjacko
PostPosted: Sat Aug 08, 2026 7:23 am    Post subject: Crown Wheel And Pinion Identity Reply with quote
Trying to identify the car that this New Old Stock CW&P in a packet
It is a 7/36 ratio
Crown wheel is 6" diameter with 2 13/16 centre hole and 10 3/8" mounting holes.
It is in a packet of company called Walben. They supplied parts for British and continental cars.
1985 Rover SD1 VDP
PostPosted: Sat Aug 08, 2026 7:35 am    Post subject: Reply with quote
Pre-war and early post-war Standard 8 hp and 10 hp light cars used a 6-inch outer diameter crown wheel with a 10-bolt flange pattern (3/8" bolts) and a 7/36 final drive ratio.
