UKdave2002 Guest
Posted: Thu Jan 11, 2007 6:27 pm Post subject: Speedo Clear out |
I’m having a clear our, this will be the 1st of a few listings. The following are speedo’s a couple are unused and a couple of other clocks, unfortunately I don’t know the applications for them, if you recognise any of them let me know and I’ll label them. Some of them are rough, if you want any more detail let me know, I’ll leave them on this forum for a couple of weeks and then stick any that are left on eBay. Hope they are use to someone.
Cheers Dave
Speedo 1
Speedo 2
Speedo 3
Speedo 4 (other gauges)
Speedo 5
Speedo 6
Speedo 7
Speedo 8
Speedo 9
Speedo 10 (Tacho)
Speedo 11
Speedo 12
admin
Posted: Thu Jan 11, 2007 7:05 pm Post subject: |
Hi Dave
third one reminds me of the P5 Rover, seven is a Triumph I think, 9 may be a Mk2 A40 but I'd need to check, ten again I think is Triumph (early Spit? or 13/60 Herald?)
I did wonder if I needed the Austin one at the end, but I think my clocks have a black dial, white letters
Rick |
UKdave2002 Guest
Posted: Fri Jan 12, 2007 11:23 am Post subject: |
Hi Rick, from what I can remember this style of gauge was fitted from around the mid 30's till late 40's either side of that had the black dial white lettering, if anyone is interested I'm pretty sure the matching "oil, Temp, Fuel" binnicle is sitting in another box! somewhere! I'll have a dig over the weekend.
admin
Posted: Fri Jan 12, 2007 11:32 am Post subject: |
Dave, this is the dash from my chrome rad 10 (1934), at the time of photographing with one odd clock (since replaced)
The '35 on 10 Lichfield also has dials of this style. I did wonder if your dial was from a just-postwar 8 or 10? or maybe a larger 30s model such as the 16?
Rick |
