nigellawton009 Guest
Posted: Thu Nov 09, 2006 12:46 pm Post subject: Replacement lamp lenses etc |
Hi,
I am a stockist of the Alumilite range of resin casting products in UK. These include a clear urethane resin which can be dyed to produce reproductions of vintage lamp lenses. I stock quick setting RTV rubber and even quicker setting mould putty which can be used to make a mould from even a cracked part. I am stocking the clear resin and dyes to make the actual lenses. Multi-colour lenses are possible. I am an experienced caster and can advise on techniques and help with any problems that may arise. I am backed up by Alumilite tech support from USA. Other parts can also be reproduced, such as trim and even switch levers. Metallic finishes can be produced using Alumilite metal powders which I am also stocking. I stock opaque resin in natural, white and black colours along with rigid foam resin which is good for reproducing larger parts.
Please visit my website http://www.nigellawton009.com/PayPalCasting.html and email me with questions.
Regards
Nigel Lawton
NigelLawton009@yahoo.com |
buzzy bee Guest
Posted: Thu Nov 09, 2006 8:55 pm Post subject: |
Sounds good, will have a look at your site later.
