UKdave2002 Guest
Posted: Mon Feb 05, 2007 2:03 pm Post subject: Can you ID this tool |
Its not a quiz I don't know the answer !
I was using my old Britool socket set over the weekend ,on the Morris 8; Whitworth nuts and bolts, not sure how old the set it does anyone know ? Notice the hexagonal not square shafts.
There is one socket that is odd see below.
It looks like some sort of key, but the fact its part of a socket set implies it had a common use ? can you id it? the top section pivots on the split pin(you can also see it in the main pic, top right 2nd socket from the end) |
buzzy bee Guest
Posted: Mon Feb 05, 2007 4:29 pm Post subject: |
I know what this is for, I have used them before, I can see the two holes that the pegs slot into. I can't for the hell of me think what it was, it is on the tip of my tounge but wount come out, I will keep thinking, please if someone can help I would apriciate it!
I think it was like a plug, that fitted flush to the surface, hence needing the two pegs, simmilar to on a grinder, (thats the type of application I used it for, whether that is it's intention I am not sure, and I can not remember the machine!) ?????
Agggggrrrrr
So anoying!!!
oldgoaly Guest
Posted: Wed Feb 07, 2007 6:25 am Post subject: |
well pexto uses a 2-hole for their beader/jenny dies, i've seen it somewhere else but??? steering wheel nut? maybe? Thats a good one! tt |
pigtin Guest
Posted: Thu Apr 19, 2007 12:17 pm Post subject: |
I also have a Britool socket set with one of these in it. It is a shiny chrome and has never been used.
I seem to recall, in the dim and distant past, using a cold chisel to remove some sort of threaded disc for the want of one of these but I cannot remember what its application was.
I will sleep on it. |
pigtin Guest
Posted: Thu Apr 19, 2007 12:47 pm Post subject: |
It was preying on my mind so I went to the American 'Mc Master-Carr' tool catalogue.
There is no illustration of this particular socket but there are 'adjustable-Face Flange-nut Wrenches' illustrated and fixed-face of various sizes available.
Is it possible that the tool had the option of changing the blade as required? Where have we seen these flange nuts? you will kick yourself..
When was the last time you changed the disc on your angle grinder?
I may be totally wrong on all this of course.
p.s. just realized that someone has already mentioned a grinder; but is it likely the tool is for applications where the flange disc is not accessible to the 'C' type spanner? |
kaybee Guest
Posted: Thu Apr 26, 2007 11:02 pm Post subject: |
Hi, many early engine valves have slots or 2 holes in the top of the valve, so could this tool be for lapping in the valves? |
oldgoaly Guest
Posted: Sat May 05, 2007 9:57 am Post subject: |
Kaybee, that rings a bell, then there are the suction cups that can fit it also. tt |
UKdave2002 Guest
Posted: Sun Jul 22, 2007 10:26 am Post subject: |
Spotted this socket set on eBay, which has provided the answer
Kaybee was spot on!.
Mystery solved |
