admin
Posted: Sun Jan 14, 2007 1:58 pm Post subject: SU carbs |
with a new HS SU carb, approx how many turns from fully 'up' should I need to turn the jet adjuster down in order for it to be close to correct?
ta
Rick |
UKdave2002 Guest
Posted: Sun Jan 14, 2007 2:05 pm Post subject: |
Turning 12 "Flats" of the nut will be the approx starting point.
admin
Posted: Sun Jan 14, 2007 2:07 pm Post subject: |
thanks Dave, so thats approx 2 full turns if memory serves..
Rick |
UKdave2002 Guest
Posted: Sun Jan 14, 2007 2:10 pm Post subject: |
Sound about right, the rule of thumb was turn all the way in and then 12 flats back, I can't remember how many flats on the nut ! when the carb is on the car in some where inaccessible like one of Buzzy’s mini’s counting flats was easier than counting full turns!
dave |
Uncle Joe Guest
Posted: Sun Jan 14, 2007 2:13 pm Post subject: |
Yes, thats correct, two full turns. But note that this is two full turns from the jet being flush with the bridge of the carburettor. |
admin
Posted: Sun Jan 14, 2007 2:14 pm Post subject: |
yeah, this is on a Prefect with brand new Aquaplane gear on it (£££), but I don't think its been set up right. Accessibility isnt brilliant on this either
I want to get it something like before selling, but at the rate I'm going at it may have to go 'as is' for someone else to tune and fettle!!
Rick |
Uncle Joe Guest
Posted: Sun Jan 14, 2007 2:27 pm Post subject: |
In that case, you also need to know that the throttle adjusting screw is 1 1/2 turns out from just clearing its stop.
Do you want a full carb. tuning procedure? That should start a discussion!  |
Uncle Joe Guest
Posted: Sun Jan 14, 2007 2:29 pm Post subject: |
Sorry, that should read of course 1 1/2 turns in....  |
admin
Posted: Sun Jan 14, 2007 2:57 pm Post subject: |
Hi UJ
It was the initial setting of the mixture I wasn't sure about, the rest I'm not too bad on I think but a full procedure would always be handy for reference
Rick |
Uncle Joe Guest
Posted: Sun Jan 14, 2007 3:50 pm Post subject: |
Hi Rick, here it is then! Now then, who can spot any deliberate mistakes?
SU H and HS carburettors.
1: Unscrew throttle adjusting screw until the face just clears the stop. Open by screwing in 1 1/2 turns.
2: Remove Piston and Suction Chamber, disconnect mixture control wire, and screw jet adjusting screw until jet is flush with carburettor bridge (or full up if you cant). Replace parts, and check Piston falls freely on the bridge (by using piston lift pin). Turn jet adjusting screw 2 complete turns.
3: Start engine, and adjust to desired idling speed (eg, warning light glowing).
4: Turn jet adjusting screw to obtain fastest idling speed WITH EVEN FIRING.
5: As the engine speed may have increased, readjust Throttle Adjusting Screw.
6: Check mixture strength. Use Lifting Pin to lift piston about 1/32”. A) If the engine speed increases, and continues to increase, the mixture is to RICH. B) If engine speed decreases, the mixture is to WEAK. C) If engine speed momentarily increases slightly, the mixture is CORRECT.
7: The exhaust note should be regular and even. If it sounds ‘splashy,’ the mixture is to weak. If there is a rhythmical misfire, together with blackish smoke, it’s to rich.
8: Reconnect mixture control wire with about 1/16 inch free movement before it starts to pull on the cam lever.
9: Set Choke knob (on dash) to max. movement (about 5/8 inch) without moving the carburettor jet, and adjust the fast idle cam to give a fast tickover, about 1000RPM. |
admin
Posted: Sun Jan 21, 2007 6:58 pm Post subject: |
Had a look at the Prefect carbs today. Took the tops off and wound up both mixture adjusters to the top of their travel, and dropped them down equally (they were quite a way apart previously). Set the idle to something close, and once it pulled the fuel up from the tank it sprung into life. There's still a gremlin somewhere - I think the fuel pump isn't up to the job of supplying twin carbs, so that wants changing. The carb settings I think are fairly close, the plugs look a decent colour so I think the pump wants refurb/replacement as occasionally it peters out at idle, then comes back, then splutters, then comes back again to an ok idle, and repeat once again.
Sure its fuel related. I notice the previous owner who bought all the new stuff didn't replace the pump, so I'm sure that wants a looking at. Other than that it seems to run well!
Rick |
admin
Posted: Thu Feb 08, 2007 10:04 am Post subject: |
UJ, what were the 'deliberate mistakes' that you mention, havent had time to re-read your 'how to' but if you could point out where changes need making, I'll put up a page on the main site for SU carb fiddling
ta
Uncle Joe Guest
Posted: Thu Feb 08, 2007 11:50 am Post subject: |
Rick, the reference to 'deliberate mistakes' was just in case anybody had a few comments as to my explanation. As nobody has, then its OK to put it on the main site.
Are you going to do the tips section with direct links to the forum in case anyone has questions? You might have already said that you are going to do this - my grey cell isn't working today, due to the weather.
UJ |
admin
Posted: Thu Feb 08, 2007 12:55 pm Post subject: |
ah right ta, yeah I'd link back to here in case anyone has some input
cheers
RJ |
admin
