Posted: Sat Apr 04, 2009 11:19 pm Post subject: Painting 2K |
So when the time comes to paint the ford, once I have finished rubbing pannels down etc. I have bought 2K paint, what do I need to do, having not done 2K before?
I was also wondering what mask to use, 50% say only air fed, 50% say 2K one use ones are ok for 36 hours etc?
Any info on the step by step doings much apriciated.
Joined: 23 Nov 2007 Posts: 4267 Location: South Cheshire
Posted: Sun Apr 05, 2009 8:38 am Post subject: |
Hi Dave
Prep for 2k is the same as for other paints, the surface must be sound, I flatten with 800 wet&dry befor the first top coat.I, have sprayed directly over existing top coat, keyed with 800 wet n dry, I'm not sure if this is good practice! But the paint has allways adhered well, I did an mgb this way 12 years ago and its still fine!
The panels should be cleaned wipe and then a tack rag.
I mix the paint according to the mfcts spec, with an 'air drying or winter, hardener' then spend a bit of time spraying a scrap panel to get the gun set up right.
Regads the mask I have only ever used an air fed , but have seen the 3m short life ones in paint shops, but never used them.
Hope this helps, sorry if some of the spelling is off ,but am typing this on my phone! With its odd predictive text!!
Chees Dave |
Posted: Sun Apr 05, 2009 8:51 am Post subject: |
Right, thanks for the info, I still have stacks of prep to do, but trying to think about it so I am ready. I wanted to paint the back with the dints and welds showing, will it still ahere, obviously I will still key it up with 800 paper?
I am trying to do the pannels off the pickup at the minute, doors, wings bonnet etc, then got the back to do and the cab, so a bit to do before I start painting!
bob2
Posted: Tue Apr 07, 2009 8:52 am Post subject: |
| why are you leaving dents and welds showing dave? |
Dirty Habit
Posted: Tue Apr 07, 2009 6:46 pm Post subject: |
Perhaps he means the spot weld indents _________________ 1964 International Harvester |
Posted: Tue Apr 07, 2009 9:47 pm Post subject: |
No I mean welds were the truck has been repaired over the years, the load deck of an old pickup shouldn't/wouldn't be shiny and perfect, it would be covered in patches and dents, so this how it will be. The small dents in the bodywork show age and the trucks history, it is not my place to remove/cover this all up in my oppinion.
Well thats my oppinion, I understand somepeople will disagree, but this is the way Ernie the E83W wants to be, he told me!
bob2
Posted: Wed Apr 08, 2009 8:56 am Post subject: |
Oh well its urs and u can do what u like with it!!
Whats the colour scheme going to be?
I really like these small pick ups, would really love one with a wooden back though!!! |
Posted: Wed Apr 08, 2009 10:48 am Post subject: |
The colour was matched from when it was in llandudno, like a blue grey over black wings.
I will probably have a go at the signing on a scrap bit of metal, if I am any good, will do it myself, if not I know of a signwriter.
Comrade-Paul
Posted: Mon Apr 13, 2009 9:43 am Post subject: |
I got some mixing cups of the paint guy, but they aren't clear when I got hone, looked at them, and the measurements are on the outside, and they are opaque, polystyrene like cups.
Will try to get some clear ones from a friend up the road!
Posted: Thu Apr 16, 2009 1:31 pm Post subject: |
Is the life of the 36 hour masks, from the time you open the seal or 36 hours painting?
Dave re the cups, who ever supplies the paint will give you a few cups for free.
bob2
Posted: Thu Apr 16, 2009 1:47 pm Post subject: |
Hi Paul I have been rollering 2 pack on unseen areas and mixing it 3:1 without adding thinners.
I was told I could do so by a friend sprayer.
However since u mentioned the correct way, is it the correct way for spraying only or even for brushing it or rollering it on?
Will it react in the future?
I havé not seen it react as yet!!! |
Comrade-Paul
Posted: Sat May 16, 2009 10:00 am Post subject: |
| bob2 wrote: | Hi Paul I have been rollering 2 pack on unseen areas and mixing it 3:1 without adding thinners.
2 pack hardly reacts with anything. Never seen it unless its over a siliconed surface etc.
Rollering it on is fine. Good idea! 2:1 is for spraying.
The measurements are for allowing the stuff to go off correctly. _________________
Picture taken in 1960?? |
fordf350camper
Posted: Sun May 17, 2009 9:48 am Post subject: |
| Is 2k were you need special breathing equipment.Or is that 2 pack paint. |
