Invicta Guest
Posted: Sun Jul 01, 2007 8:13 pm Post subject: Yazaki Speedo |
Another small (?) job on my 1975 Mitsubishi J26 "Jeep".
The speedo works, the mileometer only turns on the meters(?) section.
e.g. 208094 will go up as far as 208099 then start at 208090 again.
I would like to have a spare before taking the original out. (I am hoping it's a case of cleaning the mechanism with some WD40 then adding some 3 in 1).
Has anyone any ideas whether this make of speedo was common to a range of Japanese cars of the time?
Any comments\suggestions will be very welcome.
At least it's back on the road and the vinyl top is wind and water proof - Hurrah
Kind regards, Bernard |
UKdave2002 Guest
Posted: Mon Jul 02, 2007 10:46 am Post subject: |
Hi Bernard
Glad to hear its back on the road!
Regarding you new problem, I suspect your odometer has probably got a broken gear or pin, see on the pick below there is a white pin between the 3 and 4 that turns the white nylon gear which will in turn engages with a pin on the next set of digits.
I did fix a broken pin once by , filling the break flat, drilling a small (same diameters the pin) hole and the super gluing a suitable replacement pin.
You may find the white gear is siezed up, and if all is still in tact you will normally hear a "click " as the pin flexes over the gear without turning it, normally this this results in either the pin or gear eventually snapping !
Good luck
Cheers Dave
1nvicta Guest
Posted: Mon Jul 02, 2007 1:17 pm Post subject: |
Dave,
The picture is very useful. Thank you for taking the trouble to post it.
I am sure your method will do the trick.
If not you have given me an idea -
I used to do a fair bit of modelling (1/8th scale Jeeps for instance), so with a bit of luck and maybe some plastic moulding I can get this sorted.
Kind regards
Bernard |
Invicta Guest
Posted: Tue Jul 03, 2007 7:47 pm Post subject: |
Job Done!
It was the old grease which had turned into almost glue on the plastic\nylon parts.
Some WD40 then 3 in 1 and away it went.
It was not quiet the same as the picture (more drums with cogs attached) but the principle is the same.
The meter/yards cog was more worn than the others so I swapped it for the one furthest away.
Once again, thanks for the tips. They gave me the confidance to get stuck in and have a go myself. Bernard |
