UKdave2002 Guest
Posted: Fri Jul 20, 2007 12:12 pm Post subject: |
I was once told to apply brake fluid to preserve rubber ? I can see the logic but if you do it I'd test it on a small section first!
buzzy bee Guest
Posted: Fri Jul 20, 2007 5:36 pm Post subject: |
You can get a solution that you paint on, that restores cracked window rubbers, I have never used it, but I have seen it in the Frost Catalogue.
We used to use Red rubber grease on rubber on the sprayers, and it stoped it perishing for a while, even with the harsh chemicals on. I have some somewhere if you need some, or you can just use vasaline, but I have only ever used red rubber grease.
Uncle Joe Guest
Posted: Sat Jul 21, 2007 10:40 am Post subject: |
Assuming the rubber hasnt started to crack or perish, you can also use talcum powder....I wonder if it can be purchased with 'scent of Castrol R'???
UJ |
Penman Guest
Posted: Sat Jul 21, 2007 12:49 pm Post subject: |
What was that stuff we used to use on model aircraft elastic?
Was it soft soap or something branded?
It kept the rubber supple for much longer considering the stress we were putting it to winding them up before flight. |
kaybee Guest
Posted: Mon Jul 23, 2007 8:15 am Post subject: |
Hi Rick, I've had good results with Medicinal Glycerin,available from most pharmacies but comes in small bottles and it looks like you might need a bit more than that We had some '41 Willys quarter vent window rubbers that were rock hard , painted the stuff on a few times and left it sit for a couple of weeks and it gradually softened the rubber up and we were able to use them again, lasted about 15 years. Hope this helps, cheers, Col |
Uncle Joe Guest
Posted: Thu Jul 26, 2007 10:42 am Post subject: |
The brake fluid on rubber that UK suggested is an old trick used by secondhand car dealers to make tyres look better....
UJ |
Rivet_101 Guest
Posted: Sat Aug 11, 2007 6:13 pm Post subject: |
| don't get it on your paintwork though! |
rustyreks
Posted: Tue Aug 26, 2008 7:16 am Post subject: preserving old rubber |
I would stick to the glycerine i just used some on some old austin rubber
boots to tidy them up if it has perished you may need to buff the surface
as well with some light sandpaper and then apply the glycerine other
products that would also work are silicon spray or armourall these are
designed to protect rubber or vinyl denatured alcohol is a good rubber
cleaner the worse damage done to rubber parts is oil and grease and just
dirt and grime so if you wash the oil and grease off with some petrol and
keep the rubbers clean and use some above protectants the parts should
last much longer. brentnz |
Posted: Tue Aug 26, 2008 10:39 am Post subject: |
I can't remember which way round this is (very helpful) but there is a big difference between natural rubber and synthetic rubber.
One is attacked by brake fluid and the other is attacked by oil.
(You must always use mineral oil in Citroen hydraulic systems but never in normal braking systems.)
Another piece of probably useless advice I'd pass on is a trick I was told about just recently. If you have a tape recorder, record player or video recorder that has tired rubber belts and wheels then these can be revived by boiling them in water for 10 or 12 hours.
Peter |
Posted: Tue Oct 14, 2008 8:11 am Post subject: |
Just to revive this old thread about preserving old rubber products, rustyreks has sent over this info which may be of use to anyone wishing to preserve rubber items. I wouldn't recommend reviving cracked tyres in particular, but things like my trailer's rubber wings could well benefit from this treatment.
"I just bought some old rims and tyres for my thames pickup they are pre 1948 rims, they are 18" and were available for commercial vehicles only, quite hard to find have only seen them advertised a couple of times over the last 3 years and only one or two rims not 4. I bought these for 155.00 nz, freight was 120.00 to get them here but still think that's a good price, the tyres are in good order a couple are retreads very old.
The rims and tyres were all dusty and dirty and covered in old paint so I
cleaned them up.
Here's a couple of pics of before and after they have good tread and no major cracking so are useable I just washed them with some soap powder and used a wire brush to remove the over spray and a lot of elbow grease I also treated them with glycerine as I have some available it restores the condition of the rubber. I have used spray silicon crc and had good results or have heard others use armoural they
are not painted its just the natural rubber made me think that by treating
the old tyres will make them last longer by reducing cracking and perishing as well as improve their appearance. Dirt oil and solvents are a threat to old tyres.
One of them still had the original firestone label they are very old, a couple were made in south Africa amazing what a clean up will do am pleased I bought them now. Brent" _________________ Rick - Admin
SV8Predator
Joined: 24 Aug 2008 Posts: 137 Location: Further up the creek
Posted: Tue Oct 14, 2008 7:45 pm Post subject: |
| Quote: | | the tyres are in good order a couple are retreads very old. |
| Quote: | made me think that by treating
the old tyres will make them last longer |
These tyres are not in 'good order'! They are potential deathtraps and should be scrapped immediately.
You're not actually intending to use them on a road vehicle are you?
I thought we'd got this message through to everyone through club magazines, forums, etc. |
Posted: Wed Oct 15, 2008 1:56 pm Post subject: |
Waxoil claims that it can be used to preserve/extend the life of rubber parts. I have little experience of using it for that purpose, but they make the claim that it will not attack Chassis rubber parts.
PAUL |
SloResto
Posted: Tue Oct 21, 2008 12:57 pm Post subject: |
What an interesting thread! Like an earlier poster I have heard that vaseline is a good rubber treatmnet. I have used it on my old Ph 1 vanguard screen rubbers which were pretty bad and am hoping that they will last me until I can afford to replace them.
A tyre shop once told me that the greatest enemy to tyres is ultra violet light and that is why cars parked under cover will have longer lasting sidewalls than those left in direct sunlight.  |
Posted: Tue Oct 21, 2008 11:19 pm Post subject: |
Tyres still degrade and harden and develop flats - anything over 10 years is very suspect and even newer in hot climates.
People have died in classics and modern cars driving on old rubber - if you do not mind killing yoursrlf the others that will be involved may not share your views _________________ Rover P2
