Rodney Clarke Guest
Posted: Sun Jun 12, 2005 7:26 pm Post subject: Installing spotlights on Rubber bumpered MGB |
| Been restoring a rubber bumpered MGB roadster and now want to fit a pair of spotlights.I don't want to drill bumper.Best advise to date is to bracket them off mesh between bumper and radiator.Could do with any ideas to help me make a good job. Thanks |
Posted: Tue Jun 21, 2005 11:15 am Post subject: re:spotlights |
Yup I had a look at a rubber bumper MG the other day, I think the only option is to run a bracket thru the small grille beneath the main bumper, assuming there is something substantial enough under there to securely mount brackets on?
hth
Rick |
Rodney Clarke Guest
Posted: Tue Jun 21, 2005 10:27 pm Post subject: Re: re:spotlights |
[quote="Rick"]Yup I had a look at a rubber bumper MG the other day, I think the only option is to run a bracket thru the small grille beneath the main bumper, assuming there is something substantial enough under there to securely mount brackets on?
hth
Rick[/quote]
Thanks,Rick.Confirms what Moss' chap at Darlington told me.Might be able to get a short piece of flat steel on back of grill to spread load.This chap advised me not to use a badge bar cos I'd get too much shake on lights. Cheers,Rodders |
Posted: Fri Jun 24, 2005 9:09 am Post subject: bracket |
Aye I think you would have to watch the overall weight of lamps, badge bar etc
good luck
Rick |
