Line shafts
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> General Motoring & Collectables
PostPosted: Wed Aug 29, 2007 4:59 pm    Post subject: Line shafts Reply with quote
How do you set a line shaft up, obviously only a small one, but one powered by a stationary engine perhaps?
Anyone ever done anything with shafts, slip pully's and the rest of it?
PostPosted: Wed Aug 29, 2007 5:25 pm    Post subject: Reply with quote
If you can get over to Rowsley on the A6 between Matlock and Bakewell, you will find that there is a multi-storied flour mill, which is open to the public, powered by line shafts driven by a sunken turbine in the river.
http://www.derbyphotos.co.uk/areas_p_z/rowsley.htm
http://www.cressbrook.co.uk/visits/caudwell.php
I would think that someone there would be really happy to chat about the mechanics.
Uncle Joe
PostPosted: Sun Sep 02, 2007 10:23 am    Post subject: Reply with quote
Buzzy, what kind of belts are you going to use from your line shaft, flat or Vee?
UJ
PostPosted: Sun Sep 02, 2007 11:38 am    Post subject: Reply with quote
I was thinking of flat belting, but I am only thinking about it at the moment, not actually making it. He he
I like the look of that mill, I may go over there as I have an interest in mills, thasnks for the link!
Uncle Joe
PostPosted: Sun Sep 02, 2007 12:08 pm    Post subject: Reply with quote
Buzzy, if you are thinking of flat belting, then you have to make sure that the pulleys are crowned, and that shafts are something like parallel.
Why not visit Trencherfield instead?
UJ
PostPosted: Thu Sep 06, 2007 5:15 pm    Post subject: Reply with quote
Just been to Manchester Museum of Science and Industry.
Found these a full size Line shaft work shop and a working model of one as well.
PostPosted: Thu Sep 06, 2007 5:35 pm    Post subject: Reply with quote
Where abouts in Manchester is that?
I will probably be spending alot of time in Manchester Shortly, so may call in there!
Thanks for the pictures, and for remembering this thread!
PostPosted: Fri Sep 07, 2007 12:21 am    Post subject: Reply with quote
Liverpool Rd in the Castlefield area.
http://www.msim.org.uk/
From the top floor in one building you can also look down into Coronation St.
Part of the site is the original station on the Liverpool and Manchester Railway.
If you were coming in from Cheshire by train, or tram using Alty as a park and ride, it is relatively close to Tram, or Deansgate Rly., stations.
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> General Motoring & Collectables All times are GMT + 1 Hour
