MOT regulations
rdover
PostPosted: Thu Sep 13, 2007 8:57 am    Post subject: MOT regulations Reply with quote
A question I can't seem to get answered on the DVLA or VOSA sites.
What are the rules and date limits (if any) on MOTing a 1912 registered car?
PostPosted: Thu Sep 13, 2007 4:46 pm    Post subject: Reply with quote
See if there is anything on here:
http://www.motuk.co.uk/manual/contents.htm
UKdave2002
PostPosted: Fri Sep 14, 2007 11:00 am    Post subject: Reply with quote
The general rule is that the car should only be tested to a standard relating to when it was made, more specifically if it is pre 1931 virtually anything passes! there are many regulations that have been brought in that pre 1931 cars don't have to adhear too.
You will have no problem getting it through a test as long as it works as it did in 1912
You can post specific MOT questions to testers on this forum;
http://www.motester.co.uk/forums/
rdover
PostPosted: Fri Sep 14, 2007 11:19 am    Post subject: Reply with quote
That's great info.
The tster is a good friend but I realise that his MOT ticket is his livelihood and I am not prepared to do anything that would risk it.
Considering an 1900s car's brakes were often wooden shoes pressed against the solid rubber tyre mine are positively modern!
