Glenn Crawford Guest
Posted: Wed Oct 03, 2007 5:55 pm Post subject: |
Thanks for all this... I'm not ignoring you all but shan't be able to follow it up for a few days, but I'll be back on the case as soon as I can and will report what happened next (if anything!). |
Posted: Thu Nov 08, 2007 10:52 pm Post subject: |
To close the topic (for me, at any rate):
In the end, the solution was as simple as a partial blockage in the airway within the gun. I discovered this when I hooked up a compressor with a higher pressure rating. After a few minutes of no progress at all I was sulkily blasting air through the non-working gun when there was a sharp "phutttt!" followed by a stream of grit at high force. So there we go.
Thanks to all who gave me the confidence to see it through! |
Penman Guest
Posted: Fri Nov 09, 2007 9:44 am Post subject: |
Sounds like it was a BLAST from the past! |
