UKdave2002 Guest
Posted: Sat Oct 20, 2007 7:30 pm Post subject: Garage Clear Out; including an MGB for £99! |
Having a clear out so that I can recover some space! Am offering them on this forum first if no takers I will put them on eBay.
Crypton 350 Motorscope Tuner £30
15 mins with your car attached to this will take hours of fault finding guess work out on ignition, carb and other engine faults.
These are just the best bits of kit to have, and they are not difficult to use, I will show who ever wants it how to use it, and will include a copy of the instruction manual, and a training manual which has examples of faulty displays and the causes for all tests.
The only problem with it is that the arm is bent, and the rubber tubes that are used for the cylinder compression tests need replacing, I never replaced them as I have a normal compression tester.
An MGB GT £99 yes £99
It looks a mess, but is pretty solid, the previous owner had new, sills, floors, Inner wheel arches, rear wings replaced. It needs a new rear valance (which is included) and new door skin (also included) about an hours welding on non structural stuff. It also has new carbs, stainless steel exhaust, sport manifold and a refurbished genuine Webasto folding roof.
It will need all the paint stripping and repainting, and all the interior sorting out, and the bonnet is shot. It is however a 1972 car so is tax free.
The engine runs fine, the gear box and overdrive are all ok.
I would like the car to go to someone who is going to get it back on the road. I know I could break it and get far more than £99 for it! And I don't want it to go to someone who is going to do this! So if you know someone who wants their first classic and is prepared to put a bit of work into it they can have a bargain.
Crypton 336 Motorscope Tuner £20
The motorscope bit works fine , but the digital voltage displays don't, so if used in conjunction with a multimeter you will be fine. As with the other tuner I will show you how to use it and sort you out with manuals and traing ing guides.
I can post some pics if you want. Items will need collecting from Nantwich
Cheers Dave |
commerman Guest
Posted: Wed Nov 07, 2007 9:38 am Post subject: |
I would be interested in your motorscope tuner, if you still have it. Let me know and I will make the trip for collection when I can
Mat |
