Repairing Ally castings 1912 style
Rdover
PostPosted: Mon Nov 26, 2007 5:28 pm    Post subject: Repairing Ally castings 1912 style Reply with quote
My engine top water casting (the bit that carries water from the 2 cylinder blocks to the radiator is in need of repair or renewal. Any suggestions for repairers?
The car is an Alldays 12/14HP from 1912
PostPosted: Mon Nov 26, 2007 5:41 pm    Post subject: Reply with quote
There are places that will weld ally castings, the place I used to work at used to send ally pumps off, you could see the repair, but it was always done well, not sure if it is weldable though, I supose it may be worth looking into.
How complicated is it? Recasting it could be an option?
PostPosted: Mon Nov 26, 2007 5:53 pm    Post subject: Reply with quote
What has happened to the thread with all the pics of the Alldays?
There was a bloke at the Astle Hall meet who was doing allie welding and selling the gear for it, perhaps someone else who went remembers who it was.
PostPosted: Mon Nov 26, 2007 5:54 pm    Post subject: Reply with quote
I guess it depends how bad it is? any chance of a pic?
Uncle Joe
PostPosted: Tue Nov 27, 2007 8:40 am    Post subject: Reply with quote
Back in the day, aluminium used to be brazed, (using oxy.acet) not welded.
Nowadays, there are other ways, Lumiweld for non-stressed parts, TIG welding, or even MAG...
Are you sure it is Aluminium, and not a Zinc alloy?
Rdover
PostPosted: Tue Nov 27, 2007 9:56 am    Post subject: Reply with quote
Thanks for the responses, guys.
The Alldays thread is still running but this is a subject in and of itself and may be useful to everyone.
I've found a company advertising in The Automobile called Cast Iron Welding Services. I'm going to talk to them.
I'll update the Alldays thread soon.
PostPosted: Tue Nov 27, 2007 10:05 am    Post subject: Reply with quote
Lockstitch in Rochdale repaired a myriad of cracks in my (iron) Dodge block, not sure whether they do alloys too but might be worth asking the question
PostPosted: Tue Nov 27, 2007 11:12 am    Post subject: Reply with quote
The reason I asked is, I couldn't find it and you only have 2 posts according to your profile.
PostPosted: Tue Nov 27, 2007 11:25 am    Post subject: Reply with quote
when your logins were re-created, the system effectively looks at you as a new user, and the post count starts from zero all over again - sorry! this also means that if you posted a while back (pre- login fiasco), and chose to be notified of replies to your posts, this won't work, it'll only work on new posts using your re-created ids
