dazdawn2007
Posted: Thu Jan 31, 2008 9:08 pm Post subject: body prep time |
we its getting near the time for body prep....
wat is the best way to tackle this. ie what sort of sander and git paper etc
thanks |
Posted: Thu Jan 31, 2008 11:16 pm Post subject: |
Not an straight answer - it depends what you want to do and what the state of the body is and work done to it!
A sander is only part of the process and may not be even necessary _________________ Rover P2
Uncle Joe Guest
Posted: Fri Feb 01, 2008 8:47 am Post subject: |
Theres to many variables to give you a good answer. Personally, I always go down to bare metal, but I know others dont.
I suppose that a lot depends on the quality you want from the finished job, and the amount of work you want to put in. |
Joined: 23 Nov 2007 Posts: 4267 Location: South Cheshire
Uncle Joe Guest
Posted: Fri Feb 01, 2008 9:02 am Post subject: |
There is this link as well.
http://www.autobody101.com/
Which should provide some comments!  |
Uncle Joe Guest
Posted: Fri Feb 01, 2008 9:36 am Post subject: |
True enough Rick, but even if someone else is doing the paintwork, its good to have a bit of knowledge beforehand.
UK's suggestion of a book is probably better than my link. Its always nicer to have a book in front of you instead of a monitor...  |
