body prep time
dazdawn2007
PostPosted: Thu Jan 31, 2008 9:08 pm    Post subject: body prep time Reply with quote
we its getting near the time for body prep....
wat is the best way to tackle this. ie what sort of sander and git paper etc
thanks
PostPosted: Thu Jan 31, 2008 11:16 pm    Post subject: Reply with quote
Not an straight answer - it depends what you want to do and what the state of the body is and work done to it!
A sander is only part of the process and may not be even necessary
Rover P2
Morris Mini Traveller Mk2
Uncle Joe
PostPosted: Fri Feb 01, 2008 8:47 am    Post subject: Reply with quote
Theres to many variables to give you a good answer. Personally, I always go down to bare metal, but I know others dont.
I suppose that a lot depends on the quality you want from the finished job, and the amount of work you want to put in.
PostPosted: Fri Feb 01, 2008 8:48 am    Post subject: Reply with quote
There is a good book by Lindsay Porter on bodywork prep.
http://www.amazon.co.uk/Bodywork-Repair-Manual-Step-step/dp/1859606571
Uncle Joe
PostPosted: Fri Feb 01, 2008 9:02 am    Post subject: Reply with quote
There is this link as well.
http://www.autobody101.com/
Which should provide some comments! Very Happy
PostPosted: Fri Feb 01, 2008 9:13 am    Post subject: Reply with quote
I suppose it also depends on who will be doing the final paintwork? if that is going to be done by a professional outfit, then they'll no doubt have a standard that they'd want the car prep'd to. That might in turn affect how you go about prep'ing it.
Or are you going to have a go at the final paint yourself?
Uncle Joe
PostPosted: Fri Feb 01, 2008 9:36 am    Post subject: Reply with quote
True enough Rick, but even if someone else is doing the paintwork, its good to have a bit of knowledge beforehand.
UK's suggestion of a book is probably better than my link. Its always nicer to have a book in front of you instead of a monitor... Very Happy
