renault master t35 fuse board - help!
zeebests
PostPosted: Sat Feb 23, 2008 10:57 pm    Post subject: renault master t35 fuse board - help! Reply with quote
The fuseboard has blown on my 1984 renault master T35 petrol camper and I'm having great difficulty sourcing another one. Apparently it's no longer available from renault and a long trawl on the phone around the dismantlers has been fruitless. Anyone know of one that is available for parts?
PostPosted: Sat Feb 23, 2008 11:57 pm    Post subject: Reply with quote
It may be worth trawling ebay france, although you might need to do some translating to find the correct French name for the part you need. A quick look brings up some general Master bits in the Motors/Parts section, eg:
http://search-desc.ebay.fr/search/search.dll?sofocus=bs&sbrftog=1&dfsp=32&catref=C6&from=R10&_trksid=m37&satitle=%22renault+master%22&sacat=135232%26catref%3DC6&fts=2&sargn=-1%26saslc%3D3&sadis=200&fpos=Code+postal&sabfmts=1&saobfmts=insif&ga10244=10425&saslt=2&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=32%26fsoo%3D2&coaction=compare&copagenum=1&coentrypage=search&fgtp=
hth,
Dodger
PostPosted: Sat Mar 08, 2008 11:41 am    Post subject: Fuseboard Reply with quote
Hi. it might be worth you contacting the Self Build camper Club. Im sure they would know where you could get a replacement from. There are some Renault owners on the site. Regards Nick.
http://sbmcc.co.uk/forum/index.php?&CODE=00
PostPosted: Sat Mar 08, 2008 8:24 pm    Post subject: Reply with quote
Hi there
Very Happy
When you say the fuse board has "blown", what exactly has gone?, just that there is not much can go wrong on those boards unless phyicaly damaged or corrodied? If its the odd circuit you could put a sepertate board in for both fuse and relays?
Cheers Dave
zeebests
PostPosted: Tue Mar 11, 2008 5:23 pm    Post subject: still searching Reply with quote
hth,
Thanks for the tips...I've not had much luck. Even been thinking about buying an old one from ebay france and just flying over for the board! Tried the internet part finders too and the self build campers club
zeebests
PostPosted: Tue Mar 11, 2008 5:26 pm    Post subject: Reply with quote
ukdave2002 wrote:
Hi there
Very Happy
Cheers Dave
I had a look at the board and it consists of two boards soldered together. One of the boards has a burn hole in one of the circuits and when I connect up to the battery there's a whiff of burning from it! A auto electrician said it would be 250-500 euro just to look at it. Don't know how I feel about starting to unsolder the thing tho....
