Newbie
steveglazier
PostPosted: Fri Mar 28, 2008 10:49 am    Post subject: Newbie Reply with quote
Not sure if i have already posted this on here but anyway,
my name is Steve live in Stoke on Trent currentley working on my 100e Anglia, plans are 2ltr engine a few mods for track and road use..
Have joined a few other sites as well
http://www.invisionplus.net/forums/index.php?mforum=ford100ecom&act=idx
or http://www.nsra.org.uk/
and my own http://steveglazier.bravehost.com/
PostPosted: Fri Mar 28, 2008 11:04 am    Post subject: Reply with quote
Hi Steve, welcome to the forum - do you have any pics of your 100E? there are quite a few Ford fans on here Smile
Job-Rated
PostPosted: Fri Mar 28, 2008 11:56 am    Post subject: Reply with quote
Saw you sign up to the NSRA board...
Welcome here, too.
stuchamp
PostPosted: Fri Mar 28, 2008 1:49 pm    Post subject: Reply with quote
Welcome aboard! Very Happy
steveglazier
PostPosted: Fri Mar 28, 2008 1:53 pm    Post subject: Reply with quote
THANKS this is the Anglia i bought less engine so was ideal for what i wanted, at the moment it is strippet . all it requires is two sill's and a small patch to a rear arch and some time cleaning the rust areas.
still spending money on bits so have no date set to finish it
[img][/img]
PostPosted: Fri Apr 04, 2008 11:03 am    Post subject: Reply with quote
Is it a straightforward job putting a 2 litre into a 100e? might be worth its own thread perhaps, outlining the work?
steveglazier
PostPosted: Sat Apr 05, 2008 11:33 am    Post subject: Reply with quote
No its not straight forward: The little sidevalve engine that sat there did not requre a lot of room so to put a biger engine in requires the bulk head to be cut and pushed back & the gear box tunnel to be cut. then there is the rest of the mods cross member, Back axle, brakes, front suspenion, better wipers not vacum fed.. Thats why i jioned the 100e forum & this site to get as much help with info and parts.
PostPosted: Sat Apr 05, 2008 4:21 pm    Post subject: Reply with quote
Welcome!
Downton
PostPosted: Sun May 18, 2008 5:15 pm    Post subject: So what engine you putting in? Reply with quote
Well fancy seeing you here!... Very Happy
