scotcando
Posted: Fri Apr 04, 2008 3:12 pm Post subject: lucas alternator repair |
I am trying to refurbish an old lucas alternator for an MGA and before I try more force can anyone tell me if the nut for the pulley is a regular thread or is it Lefthand
The nut is almost flush with the shaft and corroded so I cannot see the thread on the shaft
Great forum which I stumbled across by luck Only wish I had access to all the parts that seem to be available in the UK and not in Canada |
Posted: Fri Apr 04, 2008 6:50 pm Post subject: |
Hi Scotcado and welcome,
I am restoring an mga too and also do.a bit with vehical electrical stuff. The mga was fitted with a dynamo not an alternator, yours may have had an upgrade at some point? Either way they all spin the same way, do you know which Lucas model it is?
Cheers Dave |
scotcando
Posted: Sat Apr 05, 2008 2:37 am Post subject: re lucas |
Dave thanks for quick response I think it is a lucas ACR alternator and yes it may be an upgrade |
Posted: Sat Apr 05, 2008 9:24 am Post subject: |
it will be a right hand tread, if the nut is flush its sounds as if the pulley has been changed from the standard Lucas ACR, which is not a problem.
I rebuild an ACR a couple of weeks ago, link to the thread;
http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=4513
Which model MGA are you restoring? any pics?
Cheers Dave |
scotcando
Posted: Sun Apr 06, 2008 2:49 pm Post subject: |
many thanks Dave Finally removed the nut and after viewing your excellent posting on repair details for the lucas ACR it answers other questions I had
Re the car It is an MGB and not a an MGA as first stated
I have been helping a friend over some time who has both cars and forgot which model it was for ( age related memory )
Will post some pics in relative forum eventually |
