Kaybee
Joined: 27 Dec 2007 Posts: 147 Location: Croydon, Victoria, Australia
Posted: Wed May 07, 2008 10:02 am Post subject: |
I would be suspicious of this not being what the vendor says.
To me (who is untrained in such matters) it looks like a ute which has been converted at some point.
The vendor never actually says it is a genuine 4WD all that he says is | Quote: | | There have been some modifications done over the years which are easily recognisable. | which means nothing in real terms.
But it could be fun finding the history when you are restoring it  _________________ ROVER
One of Britain's Fine Cars |
Old-Nail
Posted: Wed May 07, 2008 10:57 am Post subject: |
| I've been a member of the Austin Counties club for several years and there has never been mention of such a project, not factory as far as I know. |
Posted: Wed May 07, 2008 3:19 pm Post subject: |
The front end of the front leaf springs appear to be attached to the steel tube forward of the front bumper.
http://www.oldclassiccar.co.uk/austinute.htm
A40 and A70 Australia |
poodge
Posted: Thu May 08, 2008 5:00 am Post subject: |
This actually looks like an Austin ute body having been dropped onto a Jeep chassis.Certainly the wheels look typical Jeep.This would also explain the HUGE ground clearance.
A local chap used to do something similar.His choices of body were a bit unusual though.1964 Holden station wagon,70'sTriumph 2000 MKII saloon,and the last one i saw was a rather hacked about Toyota Corona wagon. |
Posted: Thu May 08, 2008 6:28 am Post subject: |
I found the site below, which has some great history about Austin vehicles.
(Select Home from link) I have not found any reference to a short run version, but the e-bay model does appear to have front leaf springs.
http://www.austinworks.com/t-chass.html
Maybe someone added the springs to give more ground clearance. The front hubs do seem to be original so I can't see it being 4WD. |
Kaybee
Posted: Thu May 08, 2008 12:01 pm Post subject: |
Thanks for the replies, pretty much confirms what I thought about it being a made up item. I agree with Poodge, they look like military Jeep wheels and hubs and it's definetley 4wd, you can see the front diff through the wheel arch and the transfer case shift levers are visible in the cabin shot. Might have to go and have a look over the weekend and take some better pics, and see what it looks like up close, see ya, Col. _________________ If it's old...it's good ! |
Posted: Thu May 08, 2008 3:00 pm Post subject: |
Any chance it is part Austin Gypsy. The gypsy used the same power unit as the A70.
Early Gypsy's had swinging arm suspension, on later models there was an option for springs. |
