Alarm wiring
FAB Cruiser
PostPosted: Sat Jul 05, 2008 1:08 pm    Post subject: Alarm wiring Reply with quote
I'm putting an alarm in my car. A 57 Zephyr converted to negative earth.
It has a pair of wires for 'starter immobilisation'. This circuit will be closed when the alarm is off and open when the alarm in on to stop the started motor working. The two wires are quite heavy duty.
Should I use them to interrupt:
a) The cable from the solenoid to the starter
b) The cable from the ignition switch to the Solenoid
c) The cable from the battery to the starter solenoid
d) The cable from starter solenoid to the voltage regulator
Probably more dumb questions to follow!!
Thanks
David
PostPosted: Sat Jul 05, 2008 2:04 pm    Post subject: Reply with quote
My vote goes for b.
wrinx
PostPosted: Sat Jul 05, 2008 3:12 pm    Post subject: Reply with quote
I'd say B as well.... Very Happy
Mine had what looks like a DIY pull switch immobiliser which isolates the coil and fuel pump Confused Car will still turn over but not run...which is useful at times. When it's not been run for a while I'm able to crank it over to get some oil pressure prior to starting Very Happy
wrinx
www.alfaromeo155.co.uk | www.alfamatta.co.uk
Greeney in France
PostPosted: Sat Jul 05, 2008 7:39 pm    Post subject: Reply with quote
I tend to use the Low tension circuit as immobiliser, the wire from the dissy to the coil
www.OldFrenchCars.com
Greg
PostPosted: Tue Jul 29, 2008 11:39 pm    Post subject: Reply with quote
I would cut 'b' or as Greeney says the L.T side of the Coil as the older cars usually draw more current than the modern stuff. Most good Immobiliser relays are only rated at 30 amps!
