Mk 3 Midget Gearbox
eddie
PostPosted: Sun Aug 03, 2008 9:32 pm    Post subject: Mk 3 Midget Gearbox Reply with quote
Hi,
My 67 mk 3 midget sometimes jumps out of second gear when backing of the throttle although the sincro is ok , any ideas what is wrong . Is there anything I can do without removing gearbox.
Eddie Confused
PostPosted: Mon Aug 04, 2008 11:03 am    Post subject: Reply with quote
Hi Eddie
It will probably be a worn synchro,2nd gear gets a bit of pounding because of engine braking .
Ray the rocker
PostPosted: Tue Aug 12, 2008 4:41 pm    Post subject: second gear problem Reply with quote
Hi eddie,a couple of points----the usual problem with second gear on these boxes stem from either the detent springs on the synchro hub becoming weak---or even fracture,which allows the outer hub assembly to retain drive or dissengage on overun----this normally bevels the second gear inner teeth and the hub does`nt sit as normal. removal of the gearbox is the only option i`m afraid.
ray the rocker.
