eddie
Posted: Fri Aug 08, 2008 5:56 pm Post subject: mk 3 midget fuel pump |
My 1967 mk 3 midgets fuel pump is clicking away most of the time as if it has run out of fuel, car drives ok any ideas.
Eddie |
Posted: Fri Aug 08, 2008 7:08 pm Post subject: |
Sounds like the little valves in the pump might need cleaned. It's not difficult
to do. You only need to unscrew the inlet connection boss and the filter which is 180 degrees removed from it. Just make sure you take note of the order that things come out in.
Peter |
Rich5ltr
Posted: Fri Aug 08, 2008 7:50 pm Post subject: |
| Or it might be an air leak in the pipe inside the tank so the pump is sucking air... |
eddie
Posted: Fri Aug 08, 2008 8:39 pm Post subject: mg mk 3 fuel pump |
Cheers Peter/ Rich,
I will check it out tomorrow.
Eddie |
Finch661
Posted: Thu Feb 19, 2009 4:20 pm Post subject: |
| how would you check for an air leak in the tank pipe? my pump doesnt suck fuel in when the car is below 1/4 |
