Posted: Thu Jul 31, 2008 10:28 pm Post subject: The greatest engineering Structure. |
What do you reckon to be the greatest engineering structure in Britain.
Other than Hadrians wall my vote would go to The Forth Bridge closely followed by the GWR and the Caledonian Canal.  _________________ The Clan Chieftain |
Job-Rated
Posted: Fri Aug 01, 2008 12:36 am Post subject: |
Gotta be the Millenium Dome....  _________________ Don't run your fingers over my truck & I won't run my truck over your fingers!
Posted: Fri Aug 01, 2008 1:20 pm Post subject: |
You obviously didn't understand the question Job Related!!!!!!!!!!!!!!!!!!!!!!!
I reckon that this one would take a bit of thought. I am always fascinated by structures like wind and water mills and Newcomen engines where the building and the engineering are all one - not a modern factory unit with kit stuck in it. Then there's Telford's Iron Bridge, the Anderton boat lift, the Falkirk Wheel, and even St Paul's. Don't know how to decide - except that it definitely aint the Milennium Doom! |
Posted: Fri Aug 01, 2008 1:25 pm Post subject: |
The first one of many that sprang to my mind was the Laxey Wheel...then Blackpool Tower....which was so good the french copied it!  |
Geoffp
Joined: 27 Nov 2007 Posts: 336 Location: South Staffordshire
Posted: Fri Aug 01, 2008 11:16 pm Post subject: |
I know it's not a single structure, but last week we went up the A5 from Shrewsbury as far as Bettws-y-Coed. Telford's surveying and engineering
would be impressive today, but with the technology and equipment he had nearly 200 years ago, that must be one of the great feats of engineering.
Geoff |
old gto
Joined: 10 Dec 2007 Posts: 172 Location: Orlando, Florida
Posted: Tue Aug 12, 2008 2:55 am Post subject: |
UJ...is the Laxey Wheel the same as, or similar to the Falkirk Wheel? AMAZING piece of work there!
http://www.thefalkirkwheel.co.uk/ _________________ "The only thing I`m sure of.....is that I`m not sure of anything!" |
Greeney in France
Posted: Tue Aug 12, 2008 7:49 am Post subject: |
The Great Western Railway between London and Bristol including the box tunnel which in 1841 was the longest tunnel in the world.
IKBrunel again _________________ www.OldFrenchCars.com
