Austin A60 oil filter conversion
hampshire
PostPosted: Mon Aug 18, 2008 1:46 pm    Post subject: Austin A60 oil filter conversion Reply with quote
[img][/img]
To save doing the quite awkward and messy job of changing the oil filter element on the Austin A60 I have now fitted an oil filter conversion kit so it now takes a canister type screw on oil filter. Hopefully this will make the job much easier .
PostPosted: Mon Aug 18, 2008 2:27 pm    Post subject: Reply with quote
Keep meaning to do that to my 1275 Sprite. did you buy a conversion or get one from a breakers?
Don.
hampshire
PostPosted: Mon Aug 18, 2008 2:57 pm    Post subject: Reply with quote
I bought the conversion kit from Earlpart it cost about £37 plus postage
Pete
PostPosted: Mon Aug 18, 2008 3:53 pm    Post subject: Reply with quote
That sounds like a good idea. I was thinking about this when I last changed the oil on my Mk2 A55, the canister goes on at an angle and is designed to pour oil down your sleeve when you're removing it Sad
Roverron
PostPosted: Mon Aug 18, 2008 5:55 pm    Post subject: Reply with quote
I did this to my Series 2 Morris Oxford, it was such a blessing; it made changing the oil a pleasure instead of a chore.
PostPosted: Mon Aug 18, 2008 6:22 pm    Post subject: Reply with quote
One of the problems I had was access to it, I could only get to the original canister from underneath, but the crossmember gets in the way. Any chance of a photo showing how the conversion sits in the engine bay - can you now get to the spin-on filter from up top?
thanks, Rick
hampshire
PostPosted: Tue Aug 19, 2008 11:12 am    Post subject: Reply with quote
The conversion kit is quite straightforward to fit but it will still be a lot easier to change the filter from underneath as there is now no rubber oil seal ring to hold in place . I found keeping the oil seal in place while tightening up the canister the most difficult part the job with the old filter. It could be done from above but it means bending over a long way under the bonnet .I think it makes things a lot easier if the o/s/f wheel is removed when working on the oil filter from underneath .I will try to get a good photo of it but at the moment it is raining heavy and the car is outside .
Pete
hampshire
PostPosted: Wed Aug 20, 2008 9:36 am    Post subject: Reply with quote
Hi Rick
As you can see the screw on oil filter is a lot more accessible than the old one
Pete[img][/img][img][/img][img][/img]
PostPosted: Wed Aug 20, 2008 10:01 am    Post subject: Reply with quote
Interesting, I might look into getting one of those sometime
thanks for posting the pics
