Posted: Tue Aug 19, 2008 9:14 pm Post subject: Your choice: sub-1 litre classic |
I thought it might be interesting to put a hypothetical set of criteria together, and see what the readers here think might best fit the bill.
So, for the first subject, a handy little classic, engine upto 1 litre in capacity, ideal for town use and must be economical. Can have 2, 3, 4 or 5 doors. Spares supply must be reasonable, and not too extortionate to buy. With fuel costs as they are, this seems like a good one to mull over. Ideally it'd be pre-1973 and qualify for both zero rate tax and affordable insurance, again to keep the costs down.
What would you go for, and why?
Rick. _________________ Rick - Admin
peppiB
Posted: Tue Aug 19, 2008 10:13 pm Post subject: |
I already have one - my Morris Minor!! Although 1965 and should have a 1098 cc engine, mine has a 957 unit I rebuilt. It gets me around the city, and last week did a 406 mile round trip from Newcastle to Huntingdon on £40 worth of fuel (just over 8 gallons - near enough 50mpg) at an average speed of 60mph. Insurance for me in a high risk postcode (NE1) is £100 this year and any spare part is available off the shelf to either collect or have delivered next working day.  |
Posted: Tue Aug 19, 2008 10:23 pm Post subject: |
A nice mini! Cheap spares, can be fuel effiecient or thirsty dependant on what you do to it!
Posted: Tue Aug 19, 2008 10:24 pm Post subject: |
Sounds like you want to run this as every day transport. In which case that rules out most steel bodied cars of the era since they turn brown in the winter. Assuming it needs to be able to carry a reasonable load of junk that rules out sports cars.
My vote goes to a Reliant Rebel estate..
You could probably convert it to use Robin parts so there's no shortage of second hand (cheap) parts.
You have very little to worry about in the way of rot.
It will keep up with modern traffic holds the road well and is nice to drive.
Will do 60 mpg if driven carefully.
Hmm!
Actually, I'm getting cold feet, I don't fancy this,
Posted: Wed Aug 20, 2008 7:37 am Post subject: |
Top choice has got to be an early Triumph Herald. Everything is available for them, and being the oversized Meccano set that they are, easy to work on and maintain. A turning cicle smaller than even a Smart makes for easy town use.
Other contenders would be a 2CV, and the T700 I'm collecting at the weekend. That is going to be my DD when its finished. As I've found out this week, its only a matter of knowing where to look for parts, and they are available. |
poodge
Posted: Wed Aug 20, 2008 9:29 am Post subject: |
Let out the secret,Uncle Joe,are you referring to a Glas Isar T700?Or a different T700?
Personally,I like the Austin A35 Countryman.Probably because my first two cars were an A30,and then an A35.But the Countryman,or even a plain van,is so much more practical than a saloon.
Or how about a Fiat Multipla?The original one,not the modern bugeyed monstrosity.You're a bit vulnerable sitting right at the front,though.And I don't know if they were ever made in RH drive.But it's the ideal town vehicle.Compact ,roomy,and small turning circle.
Or,for the francophile,a Renault 4,the hatchback version.For more room,they also sold the van,with higher roof,as an estate car with rudimentary side windows and a rear seat.It's modern incarnation would be the Berlingo,which I believe is also quite popular.
Then there is Holland's pride,the DAF 33 with "rubber band"transmission.Also available as a (very)basic estate.Better lay in a good supply of the belts though
That's enough to be going on with.
Posted: Wed Aug 20, 2008 9:36 am Post subject: |
Yes, thats the one that I am referring to. Air cooled 4 stroke boxer, front engine, rear drive, small enough for traffic and parking...easy on fuel...what more could you want? |
Posted: Wed Aug 20, 2008 10:00 am Post subject: |
There are two that I think would be contenders, the A40 Farina Countryman (handy having that lift up back window), so long as the body is ok (and I know someone who does repair panels anyway), plus all the easy oil bits lifted from the A35, but with better underbonnet access.
Or how about the Standard 10 Companion?? I've hankered after a nice one of those for some time now
Has anyone mentioned the Renault 4 yet?
Interesting to see Reliants getting a mention - something about GRP doesn't gel with me though, I prefer steel bodied cars even though they like to disintegrate.
Posted: Wed Aug 20, 2008 10:30 am Post subject: |
Rick wrote: | something about GRP doesn't gel with me
Rick |
Light weight. Doesn't take much HP to get them going and the roll centre is nice and low.
Peter |
Posted: Wed Aug 20, 2008 10:42 am Post subject: |
Still dont think that a Herald can be beaten in this category...whichever way you look at things, they beat the others. Dont forget that they come as an Estate as well... |
Posted: Wed Aug 20, 2008 11:15 am Post subject: |
Uncle Joe wrote: | Still dont think that a Herald can be beaten in this category...whichever way you look at things, they beat the others. Dont forget that they come as an Estate as well... |
hmm fine if you only want a 2 door ... the Standard came as a 4 door as .. err .. standard, handy if you regularly carry people in the back, the MM you have the option of 2 or 4 doors.
Am I right in thinking that the Innocenti-built A40 had a one piece lifting tailgate, rather than the split affair of the British cars? or did I just imagine this
Posted: Wed Aug 20, 2008 11:38 am Post subject: |
Really Rick, are you moving the goal? You did say 2,3,4 or 5 doors... |
Posted: Wed Aug 20, 2008 12:14 pm Post subject: |
If I remember correctly, the australian ones had the Vitesse front as well. Maybe it should be a case of Mix'n'match?  |
Posted: Wed Aug 20, 2008 1:06 pm Post subject: |
It is easy to think of UK products here and the mini, Minor and A35 must be in the list, but there are a few continentals still worth adding to the list:
Fiat 500, NSU Prinz (or whatever the little one was called) or the later 2CV derivatives like the Ami. I guess it realy depends on what you want it for and how exclusive you want to be. |
