imfinlay
Posted: Sun Aug 31, 2008 10:23 pm Post subject: Source for correct Phillips raised csk self tappers? |
HI all,
I need to get a selection of Phillips head raised countersunk self tappers, preferably in stainless steel. I can get them from the States, but someone must sell them over here!
I've tried Namrick, the usual DIY sheds and Googling, but no luck.
Help!
Ian |
Greeney in France
imfinlay
Posted: Mon Sep 01, 2008 8:43 am Post subject: |
Thanks, but they don't do raised contersunk. I understand your comment about stainless, but the trim pieces they'll be attaching are stainless themselves. |
Greeney in France
Posted: Mon Sep 01, 2008 4:47 pm Post subject: |
Have you tried http://www.woolies-trim.co.uk/
They are great for original stuff _________________ www.OldFrenchCars.com
Roverron
Posted: Mon Sep 01, 2008 6:13 pm Post subject: |
Try www.stainlessmiddleton.co.uk .Very reliable and prompt service. _________________ To Hell with ambition, it drives a man mad, I can scarcely wake up to be fed. |
imfinlay
Posted: Tue Sep 02, 2008 12:07 pm Post subject: |
Thanks - Woolies are slotted head only, the other on is Pozi only. |
Uncle Joe Guest
Posted: Tue Sep 02, 2008 1:02 pm Post subject: |
Why phillips, and not posidrive? If I may ask? |
Posted: Tue Sep 02, 2008 4:21 pm Post subject: |
I would really prefer to fit pozidrive myself and have recently found a useful source of stainless steel hardware. Yacht Chandlers, if you live near one you may be surprised at the stock of SS fixings they carry.
Don. _________________ Due to the onset of my mid eighties I'm no longer sprightly and rarely seen in my Austin special. I have written a book though. https://amzn.eu/d/7rwRRqL |
Uncle Joe Guest
Posted: Tue Sep 02, 2008 4:32 pm Post subject: |
pigtin, being absolutely pedantic, quite often its not A2 class stainless that Ships Chandlers sell, but A4 acid resistant. Its still in the stainless group, but has higher corrosion resistance. |
Posted: Tue Sep 02, 2008 4:38 pm Post subject: |
Duh! doesn't that make them better then, or have I missed a point somewhere? _________________ Due to the onset of my mid eighties I'm no longer sprightly and rarely seen in my Austin special. I have written a book though. https://amzn.eu/d/7rwRRqL |
Uncle Joe Guest
Posted: Tue Sep 02, 2008 5:35 pm Post subject: |
In my opinion, it makes them far better, but they are also a little more expensive... |
imfinlay
Posted: Tue Sep 02, 2008 9:55 pm Post subject: |
I don't mind pizi where they can't be seen, but for interior and exterior trim pieces (especially in my eye line) they're just wrong for a '50s Yank. |
Posted: Tue Sep 02, 2008 10:06 pm Post subject: |
How many people would spot the difference? I usually don't until I try to use the wrong screwdriver. Then technology is brought to bear by grinding the tip off a Phillips driver when using it on a pozi... And swearing a lot when I need it for a Phillips. Or is it the other way around?
Should know, I used to teach people these things... but ze little grey cells are not what they used to be. _________________ Due to the onset of my mid eighties I'm no longer sprightly and rarely seen in my Austin special. I have written a book though. https://amzn.eu/d/7rwRRqL |
Greeney in France
Posted: Wed Sep 03, 2008 7:12 am Post subject: |
If you don't have any luck give me the size and I will look here, the frenchies use and sell more Philips than posidrive especially in the body work shops
We cant bemoan imfinlay, we are just as fussy posidrive does look different and if its not right, its just not right
Brian M
