grahame
Posted: Thu Sep 18, 2008 8:16 am Post subject: Jensen Interceptor regulator |
My Jensen Interceptor, which I use for classic car hire, has twice failed (in 18 months) due to the regulator failing. On both occasions there have also been problems with the battery - first one was on the car and duff, second one was a duff replacement - which may have contributed to the problem but I'm not sure.
However, two failures seems more than coincidence. Does anyone have any suggestions about what else I should be looking at rather than just replacing the regulator?
Similarly, the wipers have now failed twice - second time on a replacement (original stock) switch.
The car does a high mileage (for a classic) and is otherwise fine!
Any suggestions? _________________ Graham Eason
Great Escape Classic Car Hire
www.greatescapecars.co.uk
www.greatescapecars.blogspot.com |
Posted: Thu Sep 18, 2008 3:59 pm Post subject: |
Hi Grahame,
I assume an Interceptor is new enough to have an alternator. If the ammeter shows a good charge after cold starting then your batteries were probably the cause of the problem. If your charging is intermittent then it might be worth checking that the alternator brushes aren't too worn down for good contact.
Joined: 23 Nov 2007 Posts: 4285 Location: South Cheshire
Posted: Thu Sep 18, 2008 4:47 pm Post subject: |
Hi Grahame
Duff batteries are pretty rare these days and regulators robust devices in normal conditions. Are you using any form of "fast Charge" battery charging or jump starting?
Some of the older cruder fast chargers will buckle battery plates very quickly, and jump starting can damage the regulator diodes if you remove the leads before the flat battery has reaches a near normal voltage.
Uncle Joe Guest
| Jensens usually have the Chrysler V8 engine, do they have the Chrysler electrical system as well? |
grahame
Posted: Mon Nov 03, 2008 7:33 pm Post subject: Jensen Interceptor |
Thanks. I'm not sure about the source of the electrical system on the Jensen Interceptor - it's a rag bag and every car seems to be different (not helped by lots of bodging over the years on most cars). My auto electrician won't touch it. The regulator may be parts related - there are stronger aftermarket options out there apparently. The wiper problem could be the motor - it's being stripped and checked anyway. I'll keep you updated, thanks for the help. _________________ Graham Eason
Posted: Mon Nov 03, 2008 7:57 pm Post subject: |
Grahame,
The alternator should be a Chrysler unit and the separate regulator is a simple single coil unit. It measures about 3" long and just over 1" wide with single terminals at each end (one in, one out).
SV8Predator
Joined: 24 Aug 2008 Posts: 137 Location: Further up the creek
Posted: Wed Nov 05, 2008 2:47 pm Post subject: |
| 47Jag wrote: | Grahame,
That's not correct.
The Chrysler regulator is completely different to what you describe and lives behind the front grille on the Interceptor. It must have a very good earth to the surrounding bodywork, the first thing to check before replacing the regulator. |
