Leaping Jaguar car mascot
PostPosted: Tue Oct 14, 2008 7:53 am    Post subject: Leaping Jaguar car mascot Reply with quote
Is anyone able to identify the age of the mascot shown here, these photos were sent over the other day but I've no info to hand on these Jaguar leaping cats.
"Hi there, I have this figurine and would like to know more of its
history can you help. It has the following serial number on its belly: 7
10091/1 WBB
Thank you"
PostPosted: Tue Oct 14, 2008 8:57 am    Post subject: Reply with quote
I suspect the answer is somewhere in these Jag World articles:
http://www.jag-lovers.org/cjw/
PostPosted: Tue Oct 14, 2008 6:27 pm    Post subject: Reply with quote
Well it isn't a 1937 one, we had a discussion sometime ago about early ones.
http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=4186&highlight=jaguar+mascot
The just post war one seems to have a round base, but perhaps that is a separate piece.
Greeney in France
PostPosted: Tue Oct 14, 2008 7:06 pm    Post subject: Reply with quote
If I can switch from my French nerd to my Jaguar nerd head I believe that the photo above is a mid 50s model, notice the little notch on the front that sat on a bonnet strip of probably a Mark 1 or 2 car possibly even the Mk7 as they changed the base for the Mk8
They were made by Wilmot Beedon hence the number so at least it isnt a repro of which there are many
www.OldFrenchCars.com
PostPosted: Tue Oct 14, 2008 8:12 pm    Post subject: Reply with quote
Just clarify the mascot varieties:
The first Jaguar cars to be fitted as standard with the familiar leaper were the MkVIII and the MkI. Prior to this the Jaguar mascot was an accessory sold separately by Jaguar agents. The first of these was introduced in 1938 and sold for 2 guineas. This mascot had a pear shaped base and could be fitted to any of the pre-war cars that had flat radiator caps and could also be fitted to the post war MkIV and MkV cars. Whilst the tail is broken off this one it does show the base shape:
Jaguar and SS Cars did not sanction any other mascot although it wasn't unknown for some owners to fit the "scolded cat" mascot that was sold by Desmo.
The mascots fitted to the MkVIII, MkI and later cars were redesigned with different bases so that they could be mounted on the bonnet (given that no radiator cap was present).
It looks as if the mascot starting this tread is a version 2a which would date from 1955 at the earliest. http://www.jag-lovers.org/cjw/cjw0302p69.jpg and http://www.jag-lovers.org/cjw/cjw0302p70.jpg
A Desmo mascot
old gto
PostPosted: Fri Oct 17, 2008 9:51 pm    Post subject: Reply with quote
Ebay has seen an unusual number of the Desmo mascot for sale over the last year, most likely fakes or copies. Still a good looking cat.
Alextriumphfan
PostPosted: Mon Dec 01, 2008 9:12 pm    Post subject: Reply with quote
It looks identical to a mascot I own. It was removed from a 1963 Mk 2 Jaguar. Notch and all.....
